Forscan and 2023 models?
BigMeatsBronco
Allan
2021 FE 2 door
0ur 2023 Wildtrak was successfully sport moded...and also no double honk, seat belt chime, added Stop n GO. all with the newest forscan release.
tsquared5
Trevor
Atlanta
2006 Honda Pilot, 90 Jeep Cherokee
That link version is over 4 months old brother. Just download the current release and you should be fine
How do you find the latest version? Thanks in advance.
Pure_energy1
Vince
Montréal, Canada
Bronco wildtrak
First post :)
Picked up my 2023 Wildtrak last week having g moved from a F150.
Carried over my OBD dongle and forscanned some things already, including Bambi mode, double honk, and window roll-up. However the Autostart stop disable (in the PSCM module) did not work referencing the latest Bronco Excel sheet.
I used the latest version of Forscan.
Has anyone been successful at disabling Autostart stop with a 2023 model via Forscan?
Thanks,
vrtical
Doug AI
GSMNP, TN
Fords
First post :)
Thanks,
Nope.
Mr. Hankey
Badlands 2d MT, GMC Sierra
I can understand why Ford would have some software programable features and not want to expose them all.
I called a couple Ford service departments regarding the sensitive panic button and wanting the key fob double press. I mentioned the exact setting but they said changing it is “aftermarket” and they can’t do it.
So am I stuck between the option of not changing any of these simple bits or downloading Russian software and doing it myself? Hoping some of you may have found a third party service chain who has a more legitimate way to change some of the settings.
GI_Jo_Nathan
Jonathan
I believe Panda advertised a while back about doing remote Forscan modifications. Not sure if it ever got off the ground.
Here you go:
https://www.pandamotorworks.com/col...ote-obd2-configuration-service-21-ford-bronco
meffie
meffie
Raven
'23 WildTrak
Basically yea for the majority. As far as the "Russian software" well pretty much EVERY Ford owner who tweaks these things uses said software, and has been for years, and years, and years.
If you'd like to take off the tinfoil hat for a bit, you can do lots of good things with it. If not, well you're going to be stuck with most of it as is.
The choice is yours. May the odds be forever in your favor...
Bronc’n Bronco
Kevin
Washington State
2023 Bronco
Anyone know when Forscan will be updated for 23 year models? Picked up my WildTrak today and hooked up soon as I got home to disable double honk and do the rear speakers, but Forscan was unable to detect the Bronco. :/
I did a bunch of stuff to my 23 Outer Banks. Double honk, yellow lights with DRL, added two modes ( Baja and Crawler). Global up. Make sure you are useing the latest cable. The on for my Mustang doesn’t work with tHe Bronco. Don’t do the auto off / on. Makes the charge indicator com on the dash.
amjump
Adam
Wisconsin
2023 Bronco
First post :)
Thanks,
I’m having the same issue. I successfully updated a few things (double honk, seatbelt chimes, etc) but Auto Start Stop did not get disabled when I made the change in the module.
jatt143
BRaptor, C63s, Defender 110
Hi All,
Just picked up 23 BRaptor and wanted to confirm that Google Doc change codes still work on Raptor models as well.
JimHarrison00
Terre Haute, IN
2023 Black Diamond 4 door Bronco
Hi all... I changed the auto stop setting on my 2023 black diamond bronco a couple months ago with forscan and it didn't do anything different. BUT .. a few days ago, I noticed that it wasn't shutting itself off anymore. Not sure if I got a software update from Ford which activated my previous forscan setting change (and not sure how to see the date last updated) but something certainly has "fixed the glitch" for me.
GI_Jo_Nathan
Jonathan
There are other things that can do this. Such as the battery being below a certain level. Normally once it happens the smart battery system has to be reset to enable it again. Could be any number of things as well.
Johnny Mo
Westchester County, NY
teachu2shoot.com
M-B GLE53 AMG, Ducati XDiavel, Jeep WK GC x3
Hi All,
I just enabled global close and disabled double honk and updated my power point outlets to shut off after 120 seconds instead of an hour - 23 Braptor. Edit - global close did not work even with changes to DDM and PDM. I was able to do Stop/Start though - edit 2 - went thru every module and enabled global close - now it works. Also disabled Star/Stop and Auto Start Stop - seems to work but haven't driven around to see if it changes after making goat/drive mode changes.
Went out there this morning and A.S.S. was back to normal - oddly enough the symbol is not in the dash though when it is turned off - I may go back and reset all the start/stop items since it doesnt seem to work. but global close, double honk and double click panic all work fine. Also the powerpoint time out works great.
