Ford Performance Tune Questions.
Scooter M'Gee
Cincinnati, Ohio
2025 Ford Bronco Squatch 2 Door
Wait, I thought this was for 2.3 tuning?
Built2Wild
Bay Area
Motorcycle
I have '23 2.7......how the initial throttle response in normal mode?
The throttle response is definitely improved, in normal mode you will get off the line a lot faster, if you are in sports mode, you can chirp the tires in a two door off the line. Also in 4LO the throttle is a lot tamer, meaning that the Bronco no longer lurches when crawling in auto. Prior to the tune, to avoid the lurching action you would have to put the transmission in manual mode an keep it in first gear to have a controlled crawl.
23OBX2.7
AB Canada
2023 Bronco
Exactly what I need to know definitely will get it.
