RHeinz
Ric
Houston, TX
Finally got the cover. Gave up on FPP (Ford Performance Parts), my f’ing points, and my dealer and bought a cover on-line @ full price.
Here are my observations/opinions on the cover:
1) Cosmetically, major bonus points and style points. Not too flashy, but it is there….
2). Very will made and comes with the proper bolts including the threaded studs for the brake line clips.
3) Well packaged!
4) The installation went flawlessly. Draining of the fluid with the original equipment cover was messy. How come you never have a rag handy when you need one?
5). The original fluid was clean…. 28,200 miles. The oil in the untrainable portion in the bottom of the housing was fairly black. It appeared to me that the housing was designed for a bottom drain as several ounces of gear oil remain in the low spot of the Dana housing.
6) If you want to utilize the drain in the FFP housing to its fullest extent, you will have to do some grinding. From the photos, you can see that the way the drain system is fabricated, it forms about a 3/8” damn.. At 60,000 miles, I will probably again remove the cover and grind out the drain to reduce the amount of untrainable oil.
7) The Motorcraft Synthetic Gear Oil, $$$$$$, is very light colored.
Ready to hit the back country!!!
Ford Bronco Ford Performance Rear Differential Cover Installed Impressions IMG_3472
Ford Bronco Ford Performance Rear Differential Cover Installed Impressions IMG_3471
Ford Bronco Ford Performance Rear Differential Cover Installed Impressions IMG_3469
Ford Bronco Ford Performance Rear Differential Cover Installed Impressions IMG_3470
RHeinz
RHeinz
Ric
Houston, TX
No grinding, just risk your life and park it on a hill, lol. I may just bulb siphon/suck that tiny bit out when the time comes.
Also, all the cool kids are painting our covers. :wink: 😁
At 73 YO, I’m past the cool kids stage..
Hmmm, I do have a Badlands Graphic on my hood however (strictly functional….. right?). I can’t do yellow or red differential covers however, too flashy for me..
Lak34ers
Troy
Seattle
3) Well packaged!
Agree. Did the cover when I did all fluids and not only does it look great it, it has a drain plug which is quick and easy.
Ford Bronco Ford Performance Rear Differential Cover Installed Impressions 20240414_161749
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
I like the diff between the OEM cover and this FPP one. Looks great and seems much more functional!
5GENIDN
Joe
Idaho
The additional bonus is the Magnet on the drain plug.... the exact same reservoir that the cover has... is in the diff housing as well. Even on a down hill slope with the cover removed the housing has a small rectangular recess on the bottom that seems to hold a couple of ozs as well. I used a rag to wipe out the bottom and found the depth.....
But yea... Nice cover. Had mine on for about a week.
jh3113
Jake
Phoenix
Subaru Outback
Nice! I did Valvoline 75W-140 instead of the motorcraft stuff, mostly because of cost. But the axle manufacturer Dana does actually recommend 75W-140, so that's a plus I guess. Caught a glimpse of my cover the other day walking back to my car and thought, damn that's cool!
Ninjak
Miami
Love that cover. It's on the to-do list.
Callelk
Larry
Idaho
Escalade ESV, Cherokee 2-Door
I drain mine on an 11% grade (driveway). I have truck chocks, not the cheap plastic ones but real ones that are rubber and used for Class 7-8 trucks. They meet the requirements for my industry and have been tested by NFPA, USFS, BLM, etc.......
One morning I was going salmon fishing and forgot that i placed them in front of the boat trailer tires. Thing would not move and at first thought the trailer brakes were frozen. My 3/4 diesel should have dragged it out even so but it would not budge. About to put the truck in 4 low when it dawned on me........Ooooops.
