orion
Jeremy
17' F-250, 17' Explorer
I would also go with a Lube Locker re-usable gasket if the stock one is bad.
BigHoof
PA
Ram 2500
2023bronco
usofa
2023bronco
Thanks for the awesome write up. This looks exactly like the Ford Performance version which it most likely is. Ford doesn't make their own stuff any more.
Neither does AC Delco if anybody is comparing ovals and bowties.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
After 3 distributor canceled orders because ARB is completely back ordered with no ETA in sight - I finally got one delivered today.
Didn’t pass 25k - so, I’m still good. Thinking I’ll do the transmission fluid at the same time.
So, consensus is to stick with Motorcraft oil?
Nchiappetta5
Nchiappetta5
Nicholas
Riverside CT
2021 4-door Bronco OBX SAS 2.7 Lux
id say stick with Motorcraft oil. Learn from my mistake and reuse the gasket without the gasket maker. it seemed like a good idea at the time but was probably overkill. if you use a thread locker on the fill plugs, make sure it has good resistance to oil. I used a red thread locker that came in a glue stick form that isn't as strong as your typical red thread locker.
Read the full forum to get a clear picture of what needs to be done and what was discussed to make the installation better.
redone17
Cold Spring, NY
Right on. Thanks for the tips.
Isn’t red for threads that you typically don’t want to remove and blue is for strong hold, but removable?
I got a new gasket due to this being a new mating surface. But, it was gonna be used based on inspection.
Nchiappetta5
Nchiappetta5
Nicholas
Riverside CT
yes, red is usually not meant to be easy to take back out. The glue stick type locker I have isn't like the typical red liquid thread locker. blue will work as well. that will be one thing I redo when I change the fluid again.
broncorik
Rob
If you are using an OEM gasket make sure you use the torque instructions form Ford, not Dana...the Dana ones are way too high for those fasteners with that gasket.
redone17
Cold Spring, NY
This is delayed yet again. Decided to install Metalcloak lower control arm skids and they’re a week or two out. Bashed one real good the other day - not detrimental - but, just enough for me to want to protect the new ones going in. I plan to do, Camburg control arms, Icon trackbar, ARB differential cover all in one day. So, this has to wait.
manolan478
Milton
Elberton, GA
2022 Wildtrak 2.7L Sas Cyber Orange
Thank you for the great write-up and pictures along with the supplies and tools needed.
M7 23
Craig
SW Florida
Ford Expedition
The Ford Performance diff cover looks similar and is also cast iron, but the Ford one also has a drain plug at the bottom which is nice. I went the Ford route as I also had some ford pass points.
Sparkherd
Sparky
South Central Texas
www.sparkherd.com
Lifelong Ford guy.
Doesn't anybody make a diff cover with a drain plug at the bottom?
That Dana cover has all sorts of holes, but not one that will drain it.
ARB cover has an o-ringed drain plug, a large vertically oriented fill hole, and a...DIPSTICK!!!
About $180.
Oh! And you can get it in red, for all ya'll Type A types out there...
Ford Bronco Installed: Dana 44 M220 AdvanTek Nodular Differential Cover (From Jeep JL Wrangler) -- DIY 20240424_202151
Ford Bronco Installed: Dana 44 M220 AdvanTek Nodular Differential Cover (From Jeep JL Wrangler) -- DIY 20240424_171938
