Karl_in_Chicago
Karl
Chicago
Thanks. I was holding out for the FP "faux locking hub" caps. Gives it a little old-school nod. The early batch from FP still had the Method center cap.
I knew the Sasquatch wheel was heavy. I thought they were 36lbs. 39lbs is worse, yet.
I love the X3's. The red letters are quite distinctive. They are a heavy tire, though. Still worth it.
While I'm not a big fan of the plethora of faux bead lock wheels I'm *really* digging the faux locks! If I hadn't seen those here first and spotted them in a parking lot or something I'd be doing a "now just what's going on here?" head scratching moment! :ROFLMAO:
Ninjak
Miami
Those are nice. My Black Rhino's Rapids are 22.5 lbs. I'm Happy for that because the Cooper Discoverer SST PRO 37s are no joke!
slacker83
IL
2024 Bronco
I never paid attention to wheel weight until I had my black rhino barstows on my wrangler, I think they were over 40 lbs a piece. My next wrangler got some really light pro comp wheels. Thanks for posting the detailed information.
crenca
Southern New Mexico
Yes. But the lighter wheel gives justification to offset the weight savings with a heavier MT 🙃 .
I measured my old Sasquatch’s at a hair over 39lbs. They’re heavy AF.
A savings of 7 or 11 pounds is still significant unsprung weight.
I wonder if there is a way to calculate the effects of perimeter weight (easily - as in online calculator :p ) in relation to rotational mass/momentum? Let's say you decrease your wheel weight by 10 pounds (most of that weight perimeter), but then get a tire that is 10 pounds heavier than OEM (again, most of the weight is perimeter), it is not like it is a wash in terms of rotational mass and how it effects braking and acceleration even if it is largely a wash (I think) in terms of suspension movement/momentum.
$60 for a single cap - so $300 for 5, am I reading that right?
Mjasi3
Chicago
these look great, and being lighter is a plus. also available and other colors. I'd go black as I'm not sure if the titanium/gray would look good on the velocity blue.
Ford Bronco Ford Performance Method 703 Wheels Weight = 28.4 lbs Screenshot 2025-02-12 at 3.26.00 PM
Cygnusx1
Cygnusx1
Missouri
Cayenne; Tiguan
What size? They look awfully close to the mr316s.. I have a set of those in 18x9 and they weigh under 28lb a piece 🤔
There's only once size available. See above post #21 for details.
Mjasi3
Chicago
Blue Hen
Delaware
18 Suzuki Vstrom 650XT, 22 Bronco Base MT SAS
Like the look of the new wheels on your Bronco. Is the wheel hub centric or did it come with a hub centric ring?
Beach_Bum
Ken
St. Augustine, FL
2023 Outerbanks Bronco
Do you know if the 0 offset and the +12 offset ones are hubcentric as well?
No. The wheels from Method that you mention are not hub centric.
The Ford Performance Method wheels are hub centric.
Ramble_Offroad
Nels
Northern CO
2014 2D JK on 35’s
Very cool, I dig those wheels. The black ones are dope.
Anybody remember how much the RTR Tech 6 0 offset wheels weigh?
Bronco_007
FL
Two ponies in the barn: 1974 U15 and 2024 U725.
Oh wow…. Bronze or Titanium on my Azure Wildtrak??? Once warranty expires my MIC top will be swapped for something better. And likely tan or brownish.
