New wheels: Analog HD or Method 705?
Scedwin
'24 Badsquatch, '95 Range Rover Classic
Hello all, going to get new 17x8.5/0mm offset wheels for my iconic silver badsquatch running 315’s or 35’s. I’ve narrowed it down to either Fifteen52 Analog HD or Method 705 in black. Anyone have experience with either/both and want to chime in to help me decide? Thanks!
B22-2023
Houston
Method 705 with bead grip? They are great, particularly if you air down for wheeling a lot.
Chipped one going over Pearl Pass last year, but that was aired down too much on those sharp rock ledges.
But you may not need it. The other ones you are looking at don't seem to to have grip technology.
Scedwin
Scedwin
Yes, would be the 705s with the bead grip and I will be wheeling with it so that is an advantage of those over the Analogs.
1979
Ben
Baltimore, MD
2023 Bronco Raptor
I have the Analogs. Love the look of them. They do not have the bead grip that the methods have but I regularly air down to 13ish psi with no issues.
Ford Bronco New wheels: Analog HD or Method 705? IMG_9117
Richterman
Badlands, Superduty
Methods if you like to air down
Scedwin
Scedwin
Great to hear the Analogs air down without issues @1979 ...that's the main differentiator I was considering between the two. I dig the look as well, I've got steelies on my old Rover which the Analogs look pretty similar to.
CoolContractor
Fred
I recommend the 705s in Titanium. I have the 17" x 8.5" +35 offset. I just bought a new 2025 Badlands Sas in Azure Blue. I don't like the look of the fenders wider than the tires, but do not want the fender delete either. I put Non Sas fenders on and I love the look. Just enough poke, but still have tire coverage. If I get too close to any rocks or trees, the tires will hit first.
Ford Bronco New wheels: Analog HD or Method 705? 20250503_172526
Ford Bronco New wheels: Analog HD or Method 705? 20250503_172441
Ford Bronco New wheels: Analog HD or Method 705? 20250503_172419
Scedwin
Scedwin
Thanks all for the input. It was a tight race, but after entirely too much internet info scraping I ended up going with the Analogs. Cheers and see you out on the trail.
Scedwin
Scedwin
I'm in the same boat. @Scedwin , what was your deciding factor?
@PC Austin I probably had three; 1) Based on all the reviews and experience I found across multiple vehicles, the Analogs performed without issue at low pressure, 2) They were $80 less (each) than I could get the 705s at, and 3) I dig the minimalist, no frills aspect of them. Here's a pic with them installed...
Ford Bronco New wheels: Analog HD or Method 705? IMG_6157
swamp2
Suggestion: Add nice pics of both wheels in the OP. Just one each would be great.
PC Austin
paul
Plugerville, Texas
2023 Bronco Badlands
What offset did you pick for these?
