Steve_In_29
St Johns, Arizona
2024 Heritage Limited, 2 Door, 1973 Bronco, 1999 Ranger, 2007 F350
Fuel fill NEEDS to be extended to side of vehicle. In its current location any spillage from refueling ends up IN the racer.
Hopefully the spare carrier has room for two.
BobbySaggz
East TN
'23 2DR Badlands 2.7AT; '24 2DR Badlands 2.3M/T
I’m on the race team as a chase/support crew member.
Are you at SEMA by chance?
I was checking this thing out this morning and was really impressed. Totally stoked to finally see a manual transmission at all, but especially on such a cool build.
Ford Bronco First Class 3 Bronco 6th Gen PXL_20251103_191350451
Ford Bronco First Class 3 Bronco 6th Gen PXL_20251103_191205901
Ford Bronco First Class 3 Bronco 6th Gen PXL_20251103_191233913
Ford Bronco First Class 3 Bronco 6th Gen PXL_20251103_191303343
Ford Bronco First Class 3 Bronco 6th Gen PXL_20251103_191941559
Ford Bronco First Class 3 Bronco 6th Gen PXL_20251103_191826990
Ford Bronco First Class 3 Bronco 6th Gen PXL_20251103_191811312
Ford Bronco First Class 3 Bronco 6th Gen PXL_20251103_191802817
Ford Bronco First Class 3 Bronco 6th Gen PXL_20251103_191537359
Ford Bronco First Class 3 Bronco 6th Gen PXL_20251103_191540688
Ford Bronco First Class 3 Bronco 6th Gen PXL_20251103_191713140
Ford Bronco First Class 3 Bronco 6th Gen PXL_20251103_191328872
Ford Bronco First Class 3 Bronco 6th Gen PXL_20251103_191321725
Ford Bronco First Class 3 Bronco 6th Gen PXL_20251103_192012981
popo_patty
Caleb
Sacramento
No I’m not this year:( next though I should be there with my Jeep build that shall not be named
Fordified1
Bob
Mid South Texas
2 things I see that I believe should be considered. The adjusters for the lower control arms should be locked into place better than stock. I saw a kit from someone (can’t remember who) that does this. And the upper mounts need the added tabs to be double sheer. Very cool truck.
52hurtz
Ben
NOVA
2025 Badlands NS 7MT
Is it normal not to run protection underneath for a Baja truck? I assume the weight slows you down too much?
UncleBrad
Brad
2024 Bronco 2-DR Manual
All those classic lines and heritage captured from the original 2-door (as God intended it to be). And a proper manual transmission to boot. Anybody else getting wondering if these specialty and concept teasers capitalize on these enduring configurations so they can bait-and-switch us later into 4-door automatic variants?
>> Powerplant................????????????????
You can bet on it.
mdainsd
2025 Bronco, 1974 Bronco, 1969 Bronco, 2014 Raptor, 2012 MegaRex
I'm starting to wonder if Ford only made the two door for that reason? If they had tried just 4 doors there might have been a bunch of criticism of Ford just trying to cash in on the name. Seems like the 2 door is slowly being whittled down.
F-Spot
SoCal
Tesla, FJ
I really like what's done...minimal lift, maintaining some OEM suspension and steering components...adding what's needed to meet Class 3 eligibility without going over the top in beefing up every little part. Looking forward to seeing this rig complete the run! Will be good to see what OEM parts held up and what parts didn't.
Steve_In_29
St Johns, Arizona
You can bet on it.
A manual in a racer is a hindrance.
Trying to maneuver at 80mph off road in sand, silt and clouds of dust is hard enough without having to row the gears as well at a time when you are better served with both hands on the wheel.
UncleBrad
Brad
Trying to maneuver at 80mph off road in sand, silt and clouds of dust is hard enough without having to row the gears as well when you are better served with both hands on the wheel.
Apparently that's not what they were thinking. Or, at the very least, they were willing to endure the shortcomings in favor of the thrill.
UncleBrad
Brad
Exactly.
Andrew Bynum
Los Angeles
21 Two Door OB Sas V6 AMB
I don’t like fastbacks and I don’t like tire poke, but man that’s beautiful.
swamp2
Yes, I would (did) definitely make this inexpensive upgrade. BDS Suspension - Alignment Cam Lockout Plates.
popo_patty
Caleb
Sacramento
Pictures are hard for me to upload where I’m at but the team is ready for tech in morning! Steve, you would be happy to know that the rack does indeed have two tires mounted, skid plates installed and fuel cell finished :) between media, chase vehicles and the race Bronco. Our grassroots, non paid race team (#301 btw) has more Broncos in our entourage then Ford Racing. The team is made entirely up of volunteers from the bronco community that want RJ (the driver), to succeed in finishing and maybe placing a top spot. There are only 2 other vehicles racing in the Class 3 spot including an older Bronco that is way more modified then us and a Toyota as well with hefty sponsoring.
Ford Bronco First Class 3 Bronco 6th Gen IMG_8165
Ford Bronco First Class 3 Bronco 6th Gen IMG_8161
