Factory wheel & tire weights - All Models
EveryDayBronco
Motorcycle
- factory wheel + tire = 57.5 lbs
- factory tire 30" dia, Bridgstone Dueler H/T 255/70R16 = 31 lbs
- factory steel wheel: 26.5 lbs
- wheel offset: 55 mm
Sasquatch
- factory wheel + tire = 87.5 lbs
- factory tire 35", Goodyear Territory MT LT315/70R17 = 52 lbs
- factory wheel: 35.5 lbs
- wheel offset: 30 mm
- factory wheel + tire = 58.25 lbs
- factory tire 32" dia, Bridgstone Dueler A/T 255/75R17 = 35 lbs
- factory aluminum wheel: 23.25 lbs
- factory wheel + tire = 74 lbs
- factory tire 31.6" dia, General Grabber A/TX 265/70R17 = 44 lbs
- factory steel wheel: 30 lbs
- wheel offset: ____mm
- factory wheel + tire = _____ lbs
- factory tire 32.1" dia, Bridgstone Dueler A/T HRS 255/70R18 = 39 lbs
- factory wheel: _____ lbs
Badlands with bead locks
- factory wheel + tire = 80.3 lbs
- factory tire 32.8" dia BF Goodrich KO2 AT 285/70r17 = 50.3 lbs
- factory wheel: 30 lbs
Badlands without bead locks
- factory wheel + tire = 78.3 lbs
- factory wheel: 28 lbs
Wild Track
- factory tire 34.4" dia, Goodyear Territory MT 315/70R17 = 52 lbs
Add the missing info if you have it, other models if you have it, and no guessing, actual measured or manufacturer's specified weight please!
HoosierDaddy
__ Eric
You want a filled weight (filled to door sticker psi specs) ..... or an empty weight (flat)?
Sorry , had to do it. LOL
EveryDayBronco
Motorcycle
Still hoping some of you weigh your factory wheels and post the weights!
Edit,
Found black diamond wheel & tire weight.
If you're looking for take-offs this is good info. If you have base and are wanting to add bigger tires you'd do better starting with a set of big bend wheels because as far as I can tell they are the lightest weight!
Tricky Dick
Dick
PNW
www.TD-Distributing.com
- factory wheel + tire = ______ lbs
- factory steel wheel: ______ lbs
Sasquatch
- factory wheel + tire = 88 lbs
- factory wheel: 36 lbs
- factory tire 3.16" dia, General Grabber A/TX 265/70R17 = 44 lbs
This will be excellent info to have all in one place.
I have an unmounted base wheel I can weigh if nobody answers first.
Raptor911
Raptor911
Broadlands, VA
thesocalexplorer
Southern California
Glad to see a # figure for the big bend wheel and tire. Didn't know the wheels themselves were in the low 20's. I was pleasantly surprised when rotating my tires this past weekend.
EveryDayBronco
Motorcycle
Thanks guys.
Now just looking for base model and outer banks!
nwGTS
Nate
Chicago, IL
I'm used to sportscar forged alloys and accompanying light tires. Near ninety pounds for a wheel and tire is bananas to me. My back hurts just reading it.
EveryDayBronco
Motorcycle
Looks wise I like the big bend wheels so I was happy to learn they're light weight!
Kstiff
Joseph
Owensboro
Sasquatch
- factory tire 35", Goodyear Territory MT LT315/70R17 = 54 lbs
- factory wheel: 35 lbs
- factory tire 33" dia BF Goodrich KO2 AT 285/75r17 = 58 lbs
Can I put 285/70/17 on a Saquatch rim for big bend?
HoosierDaddy
__ Eric
I'll take "Unrelated questions in random threads for 500, Alex".
But, generally speaking, yes ... most 285/70-17 tires will fit properly on a 8.5" wide wheel. Check the specs provided by the manufacturer for the final answer though.
I'd be shocked if any stated that was out of range for that tire.
Dad life
J
TN
Jeep, Tundra, GX470
BL Optional Beadlocks
It's a 70 series tire, not a 75...so 32.8" instead of 33.9".
BFG lists the C rated version at 51lbs and the E rated at 58. The Badlands I've seen have the C rated tire.
