I am trying to piece together info on the factory rear axles to see what opportunities there are for upgrade, interchangeability in the event of a trail break etc. If any of you have additional information, please post up below
What I have found so far (please correct me if I am wrong on any of this)
-All rear axles are an M220 gear set
-All rear diffs/shafts are 32 spline
-You can get an open diff or E-locker from the factory, is there a limited slip option?
-From what I can tell, they all run the same brake caliper with integrated EPB
-I am guessing that, similar to Jeep M220, they all run a set 80 bearing at the wheel.
-They all have the same suspension brackets
What I haven't found
-Some models have a swaybar on the rear axle, some don't. Does anyone know what options trigger this feature?
-Are there different axle housing widths?
-Do the different factory diff options change axle shaft length? I have heard that on Jeep Gladiator, depending on if you have a factory E-Locker or an LSD in your M220, there will be slightly different shaft lengths. What I am getting at here, is can you take a driver's side shaft off of any bronco and put it in any other bronco on the driver's side.
Have any of you had failures? I have heard of the tubes spinning in the center section. Have any of you bent axle shafts, tubes or blown up gears?
