Factory Fog Light Switch
mblur05
Los Angeles
2022 Bronco BlkDia. Sasquatch
I am about to update my light switch also. After popping the panel down. Are there any screws that need to come out? Is there a video out there? Thanks!!!
There's already a post a few pages back about popping the driver side dash panel down, but here is a video. It's like 40secs in, no screws it just pops in/out.
plogan1379
Patrick
Celina, TX
Ioniq 5
Can someone please advise where to order these from, the ford dealer I placed an order with cancelled it because they said its the wrong part number for me and are trying to tell me i need the HC switch…mofo I’m not trying to add front and rears!!! Just send me what I ordered idiots!!! Ugghhh
Well I have the switch for front fogs (no Bronco yet) but just realized I want a rear bumper that has integrated lights (thinking about the Rough Country one). So now, I want to get the switch with both. I can pull the puddle buttons off my factory WT LUX one when it comes in. Could sell you the one I have.
dhendriksen
Dan
4dr Badlands - Loaded 2.7 with SAS and LUX
How much with shipping to UT?
Gotchaa
Los Angeles
Tesla
Like I said, that’s not correct. The description from all these places online are saying “without blindspot” which is false.
Here is what it shows in the actual Ford parts catalog. As you can see, they are both for vehicles WITH blindspot. But you are correct about the front fogs only with DC and both front and rear fogs with BC. I didn’t look at the picture in the original post correctly.
If you have a fully loaded wildtrak, and you wanted rear and front fogs, would you use this part?
M2DZ-11654-CC
plogan1379
Patrick
Celina, TX
Ioniq 5
I have the Factory switch with Front Fogs Only (M2DZ-11654-DC) That I will ship for $60. Decided to get the switch with rear fogs.
CarbonBronco
Tony
Socal
99 Toyota $runner
Finally finished this and got around to removing the fog light from my Switch-Pros and moving it to my Oem light switch. I just tapped the brown wire and ran my Baja wiring to it to connect it. Works like a charm.
dhendriksen
Dan
FordOwner
SoCal
a few
M2DZ-11654-CC
Yes.
I have a Badlands, high trim with front fogs, puddle lights, etc. This is the right switch to order for going from front fogs to front and rear fogs. I have one on the shelf that I ordered a few weeks back.
In the second picture below, You can see the dealer I ordered from where I was able to purchase w/o being required to provide VIN.
Original in dash front fog only switch:
Ford Bronco Factory Fog Light Switch PXL_20230410_213016329
Replacement front and rear fog switch - M2DZ-11654-CC:
Ford Bronco Factory Fog Light Switch PXL_20230410_212641674
nwGTS
Nate
Chicago, IL
Is anyone who added a factory fog switch to the MOD bumper using a relay or are you all just tossing in those three pod lights per side with a hope and a prayer the amperage is good to go?
I just ordered my module and plan to install fogs at C203 front and C424 rear. Wondering if I'm going to have a funny burning smell at some point unless I use a relay.
zuke
Stafford VA
I haven't actually seen anyone using a relay with the factory switch, But I've seen plenty of people dividing the 3 light pods and putting 1 from each pod on the factory switch, and the remaining two from each pod on an upfitter switch.
I really wouldn't advise putting more on the factory switch, not because you would exceed the load rating of the wire (though you would), But because the federal standard for on road use is no more that four forward facing lights can be on at one time. Many states will fail a vehicle for safety inspection that have more. Some states will pull you over and ticket you for it,
All that said, You could use a relay, But I think you might need to add a load resistor to the inductance lead to keep the Body Control Module from throwing Lamp out warnings, and if you did have a lamp go out, you wouldn't get any warnings
Gotchaa
Los Angeles
Tesla
Yes.
I got mine today, now I am trying to figure out which wires are for the front fog, and which are for the rear in c203 location. Ideally I want to use one fog switch front for the white light, and the rear fog switch button for the yellow, this should be possible? Anyone do this yet and have pictures?
Also is a fuse required for the rear factory fog light switch?
Inlinejohn
WA
Several
With those deciding to use dual Fog switch, what lights are you choosing to install in the rear that would not blind people following? I wonder if Rear Fog could be used for Chase light??
plogan1379
Patrick
Celina, TX
Ioniq 5
I personally am going to use the rear fog switch for lights that are integrated into the RC rear bumper I plan on getting. Figured this would be a good use for that IF the lights are actually wired back to that location on my WT.
