Factory Fog Light Switch
calgecko
Sacramento, CA
www.instagram.com
2021 Chevy ZR2 Bison V6
To Go even further, it isn't even really a relay that supplies the power to the circuit, It's the Body Control Module, "BCM".
You might be overtaxing it if you try to drive all 6 of them at once from the OEM Plugs... That's 6x20 Watts per pod is 120 Watts total, 120W/12V = 10 Amps.
The Factory Fog lights are also LED, and though I couldn't find the spec anywhere, I'd guess they are also about 20 Watts each, so roughly 40 Watts total. Rigid makes a set of OEM Replacememnts, Also 40 Watt total draw...
If you want some of them running on the OEM switch and wiring,, I think I'd stick to just one pod on each side through the OEM setup, and run the other 4 off an Aux switch...
good idea - thanks!!
Cfield90
South FL
21 Bronco/22 Escape/01 Softail/90 Bronco (former)
I am still trying to get the part number for the wiring harness for those with Standard Package and Modular Bumper that DON'T have the wiring behind the tow hooks. Any insight there? Consensus is that the wiring is at the switch but terminates at C203, correct?
I don’t know, but I thought it was mentioned in this earlier pages of this thread, but looks like you have part of your question answered 🥳
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
I guess I was just confirming that new information wasn’t discovered that I may have missed since my early discoveries. It seems like I just need to track down the harness part number that connects C203 to C192.
BigBendBW
Columbus, Ohio
Bronco Base Sasquatch
M2DZ-15K867-E is the part for steel bumper with sensors. Could ignore the sensors or try to add them in as well.
Do you happen to have part numbers for front and rear steel bumpers without sensors (front preferably the capable bumper)
Bigmoose
Jon
RI
2019 Flex Ecoboost Limited
No but you can look them up on tascaparts.com
22Badskwatch
Sacramento, CA
2022 Badlands Sasquatch
Got a switch but no bronco yet 😂
this is the one I need for my Luxe Badsquatch - I want to activate front and rear foglight - what part number is this one that has the dimmer buttons and mirror light buttons?
Cweat1984
Chad
Mustang, Oklahoma
2021 Ford Bronco Wildtrak
Does anyone know where I can buy a pigtail to plug directly into the factory plug from the fog light?
rdg698
Gil
South Carolina
Ford F-150
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Bad_Bronco
Peter
Port Coquitlam, BC
1963 Chevy Nova SS, 2021 Ford Bronco WildTrak
Hoping someone on the way to SEMA can help me. I am leaving from Vancouver, BC Tuesday.
I installed the factory switch w/ fog light option, had a dealer activate the system in Forescan, and hooked up fog lights with wires already in the harness. I am getting a solid ground, and the fog light on the dash illuminates when button is pushed on. not getting a signal from the switch to the fog lights. Maybe not done properly from Dealer??
Possibly the BCM is not reading it??
I'm stuck on this one. Is there anyone that will be around RPG Off Road on Friday, that knows how to do this, that could help me out?? Headed to SEMA Saturday, with a stop at Bronco Knoll on the way. Please PM me and let me know. I would appreciate a fellow Bronco Brothers help...... Thanks.
WheelMe
Patrick
Northern California
2022 Bronco Badlands Sasquatch 2.7L
If the wires are connected properly down by the fog lights, I'd bet that the dealer didn't fully complete the FORSCAN configurations... there were a few different modules to reconfig. in there, not just one.
cyberfalco
Tony
Conway, AR
2011 JK, 2000 Ram 2500, 1993 FZJ80, 1994 FZJ80
That is what I am thinking. There are settings to enable power on each side that probably did not get done. I know that was my problem the first time I tried it.
