Factory Fog Light Switch
drew707
Ford Explorer
I'll try this, but I think the system runs a self check and checks the resistance in the micro switches in the seat belts....once the switches are removed then I get a restrains with seat belt and airbags in icon warning light, this is different than the "put your seat belt on "light.
It's the yellow one I'm trying to omit.
The yellow you’re talking is a pyro device (belt pre-tensioner) and the correct resistance to fake it out should be around 2 to 3 ohms.
WuNgUn
Ontario Canada
2 door Squatched
I'm going to have to restore my BCM module and start over...
Something weird going on with my turn signals now...
Didn't do it earlier today or yesterday, but tonight, I put a signal on, and after a few normal flashes, it's goes into double-time, hyper flash! Wtf!
Edit: just noticed today rear passenger signal light working/not working
Restored BCM from backup and Re-wrote the tables (and the chimes off bits) and so far, everything is back to working as usual.
Flipping the wrong bits of making an easy mistake can have serious and weird consequences!
‘21OBX
90Bronco19
2022 bronco outer banks
JUST noticed switching on the rear fog turns off the high beams.... Interesting
Must be tied to the fogs allowed with high beam. Mine does not shut off the brights.
LAB0035
Lex
2022 Ford Bronco Badlands
Yes you technically could. What I'm MORE curious about is the factory fog light switch.
So naturally Ford is not going to have a separate assembly line for HD Modular bumper trucks, and have a completely different wiring/dash, right? Soooo the trucks that have the plastic bumper with the factory fogs, they have a fog light switch I assume on the dash, right? What happens with a modular bumper truck? Is the factory fog light switch still there, but does nothing (which is weird) or did they remove it and put a DIFFERENT switch in? And what kind is it? Is there a blank plate there (like on the Tacomas, where they put a blank plate there).
Worst comes to worse you put an aftermarket rocker switch where that blank plate went (or get the factory one somehow, when you can get Ford parts, and wire it in to a relay as you stated). That frees up 1 upfitter since you now use a "factory" location for the fog.
Then you could do what you said, link the 2x S2 pairs to 1 upfitter (or use 2 upfitters so they are on their own, i mean choice is yours really).
The two trucks that stopped by our shop today both had modular bumpers and I never thought to check where the factory fog WOULD go. I should have! Next time for sure.
I actually like where you are going with this. WHY tie up an upfitter for a "fog" light that'll usually be on (on my raptor I always have an upfitter turned on for my fog light, it does seem pointless).
Naturally let us me know when you are ready to pull the trigger on that Baja kit and we'll hook you up
Does anyone have the Ford part # for the Factory headlight switch that has the Foglight push button option. I checked with my local dealer parts dept and they claim there is 8 different headlight switchs for the Bronco and they Need the last 8 numbers of the Vin to get the right switch
zedster
Las Vegas
'21 Bronco 2 dr Badlands SAS, '22 F150 PowerBoost
I used part# ML3Z-11654-DA for the factory headlight switch with fog button. It does require switching out the left module buttons with the ones on your current switch but it's easy to do and there is info further back in this thread on how to do that.
Razorback
Dallas
Lincoln MKX
I have the new light switch with the fog light button... thanks @flip ! I'm about to order the BD kit and then will go through Forscan to enable. Question though. Can I go ahead and hook up the new switch without the fog lights and enabling or will it through codes somehow?
flip
Phil
IN
www.ruxerparts.com
Fords
I don't think it will cause any problems. I've been wrong before and plan to be wrong again. Install it, use it for several days then shoot me the VIN and I'll check VHR.
zedster
Las Vegas
I did and it didn't cause any problems.
Razorback
Dallas
Lincoln MKX
Took literally 50 seconds. Lol. All functions work seamlessly. So we'll see in a few days of it throws a code. By the way, perfect replacement. Even had the mirror light buttons vs some that have gotten the gas and trunk button. So I didn't have to switch out the buttons!
Ford Bronco Factory Fog Light Switch PhotoGrid_1651785449875
WuNgUn
Ontario Canada
2 door Squatched
I think it you run a diagnostic scan, it'll mention the fog lights to electrical to ground issue or something, but you don't get any MIL's or anything.
IndyBD
Indianapolis, IN
Can someone please confirm the single fog light switch w/o puddle lights?
Someone posted M2DZ-11654-BA, but then someone came back and said that was the dual front/rear switch which does seem to be the case for BA & BB.
Or could I just get the single with puddle lights and then just use the bezel from the original to remove puddle switches?
Razorback
Dallas
Lincoln MKX
Did you go ahead and enable fog lights before installing. Afraid my 2 months of forscan will expire prior to getting lights and would like to go ahead and enable them just incase...
zedster
Las Vegas
All I did was put the switch in. Later (maybe 2 weeks) I made the changes once I changed out my bumper and lights.
CarbonBronco
Tony
Socal
99 Toyota $runner
So for a base bronco with mod bumper has anyone figured out what wires to tap to make the factory fog light switch work?
