Factory Fog Light Switch
WuNgUn
Ontario Canada
2 door Squatched
Hmm I did not try to turn them on with the high beams. I’ll give it a try soon.
This seems to occur only when the headlights are in auto. If I manually switch on the headlights, I can go highbeam with the rear fogs 🤷
LanCar
Sanford, FL
Can someone please confirm the single fog light switch w/o puddle lights?
Someone posted M2DZ-11654-BA, but then someone came back and said that was the dual front/rear switch which does seem to be the case for BA & BB.
Or could I just get the single with puddle lights and then just use the bezel from the original to remove puddle switches?
The correct part number is M2DZ-11654-AB.
Cfield90
South FL
21 Bronco/22 Escape/01 Softail/90 Bronco (former)
Managed to get set of @ORACLE Lighting triple fogs with whites on factory fog switch and yellows on aux 5. Somehow I neglected to see the forscan change needed to get the dash icon. Will have fix that later.
Ford Bronco Factory Fog Light Switch 1568A2BA-5FE3-4117-B145-ECDC7CA5D711
Ford Bronco Factory Fog Light Switch B1A550AF-80A4-48DF-86D6-36D368F254E3
Ford Bronco Factory Fog Light Switch F1A9089D-CB4F-488A-A20B-9136E0BA20D1
Ford Bronco Factory Fog Light Switch E3A7E399-D983-48BA-8A07-E00C891F36AA
Ford Bronco Factory Fog Light Switch C12C7005-7FC4-4FAC-A5FF-5A2D61E2ED52
Deltamav
Ben
Cherry Hill, NJ
2022 Badlands
I want to do the same thing with the fog lights. Did you connect your oracle lights to the factory fog connectors near the shackles? If so, how?
Cfield90
South FL
Yes. I essentially digested both this thread and the other spin-off thread (Updated:Fog lights added and connected to factory connector). I bought the pins to crimp and add to the factory plug, which worked nicely on one, but not the other, so I ended up cutting the factory connector off and wired directly to the Oracle male harness. For the side that did work, below is a pic. Hope this helps!
Ford Bronco Factory Fog Light Switch 7A8C85A6-C861-4D79-941D-AA423DE28087
Here is the side that didn’t go as expected. I used male/female crimps, so I can disconnect without cutting more wire, if needed.
Ford Bronco Factory Fog Light Switch image
Deltamav
Ben
Cherry Hill, NJ
2022 Badlands
This is very helpful, thank you.
As an aside - was the powder coating on your light brackets damaged during shipping? Mine was lightly damaged (no pun intended) because the brackets were rubbing against one another, and that one piece of foam between them wasn't doing a damn thing. I emailed them to see about getting a replacement, so we'll see what happens.
Gtrekker
Gary
NJ
Sadly it’ll be end of October before I see mine if everything goes to plan but I figured it would be similar to the switch in my past Fords, usually it has a button for the fog and if not that area is left blank. So basically get my switch and figure out where the foglight power is. Knowing my luck the foglight wiring is there and just tied up or cut short.
Hey, if I'm following this chain correctly... Use the headlight/fog light switch you are using now for the amber lights and use the uplifter switch for the BD lights.
Cfield90
South FL
Yes, there was some light bare metal on a couple of the edges. What was weird is there is what appears to be scuffing (not to the metal) right above the top of the lights—close to where the 3 mounting holes are.
Ducati1098
Did you go ahead and enable fog lights before installing. Afraid my 2 months of forscan will expire prior to getting lights and would like to go ahead and enable them just incase...
Just a FYI, if you set the date on your computer back, it will continue to work even after it’s technically expired. This way it never actually expires.
Deltamav
Ben
Cherry Hill, NJ
2022 Badlands
Same. I guess you get what you pay for...
cyberfalco
Tony
Conway, AR
2011 JK, 2000 Ram 2500, 1993 FZJ80, 1994 FZJ80
I appreciate all the information in this thread. I ordered the OBD2 reader so I can use Forscan to enable the fog light switch. I ordered a fog light compatible headlight switch and the JCR HD Steel bumper fog light brackets. I already had a set of Rigid pods I won years ago still new in the package to install.
https://www.jcroffroad.com/product/BR6SB-FG.html
https://www.ruxerparts.com/oem-part...ps-m2dz11654ca?c=bD0xMyZuPUNhdGVnb3J5IFBhZ2U=
https://www.amazon.com/gp/product/B081VQVD3F/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
The Pigtails are here! We're shipping them out
Ford Bronco Factory Fog Light Switch 1653592281346
CrystaLux DT 4-Pin to MX150 Pigtail, Pair (2021+ Ford Bronco w/HD Modular Bumper)
https://www.4x4truckleds.com/crysta...il-pair-2021-ford-bronco-w-hd-modular-bumper/
CrystaLux DT 2-Pin to MX150 Pigtail, Pair (2021+ Ford Bronco w/HD Modular Bumper)
CrystaLux WP 2-Pin to MX150 Pigtail, Pair (2021+ Ford Bronco w/HD Modular Bumper)
cyberfalco
Tony
Conway, AR
Awesome! I just ordered a pair now that I confirmed my Bronco has the factory harness.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Sounds good. A nice elegant solution to control 1 pair of fogs
F-Spot
SoCal
Tesla, FJ
Received my pigtails yesterday and connected them this morning. Took just a few minutes to connect and swap out the factory fog button assembly. Forscan went smooth except for when I went into IPC. Somehow, I ended up resetting the IPC rather than going into the IPC configuration. It didn't seem to affect anything, and all it seemed to do was ask me to choose what views to add to the dash display. Everything works good so far after making the appropriate forscan changes. I get power and the dash indicator.
