Factory Fog Light Switch
drew707
Ford Explorer
@drew707 this is weird... My belt minder chimes has come back...
I'll have to back over my BCM settings 🤷
PM me your VIN I’ll take a look tonight if there’s a cloud submitted DTC for it. I don’t think any of your changes should have caused this.
Edit: Sorry I forget we are in the ForScan thread. Can you see any codes that may be pertinent to this? I’d like to know the responsible module and what the code is
‘21OBX
90Bronco19
2022 bronco outer banks
The modifications in BCM and IPC correct?
I did everything in the plain English side of forscan but yes I believe there are lines in both that need to change.
WuNgUn
Ontario Canada
2 door Squatched
I'll have a look and pull any codes tomorrow morning...
WuNgUn
Ontario Canada
2 door Squatched
I forgot I had ForScan app on my phone (I'm at work)
Please see attached txt
Weird one about left rear turn signal. It's functioning 🤷
drew707
Ford Explorer
Interesting I’ll have to look into this one.
TX-Hans
JUST noticed switching on the rear fog turns off the high beams.... Interesting
There is an as-built change that allows the fogs to stay on with the high beams. Would not surprise me if It has an effect on rear fogs.
WuNgUn
Ontario Canada
2 door Squatched
The weird thing is, they stay on with the front fogs... Only the rear turn off the high beam. 🤷
‘21OBX
90Bronco19
Hmm I did not try to turn them on with the high beams. I’ll give it a try soon.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
@drew707 so went out to the truck just now...
"load all" for the IPC restored my backup from the file I saved, then I made the necessary changes... Viola!
Everything seems to work now.
I also went over the BCM and used the defaults you provided 👍🏻
Now I just need to get some ACTUAL lighting!
Thanks for your help...
Well I know a guy who can help you out with that :) And we make the pigtails for all of our kits that you can get to plug right into that factory connector Ford left you :)
BigMeatsBronco
Allan
2021 FE 2 door
Can you make a pigtail with a restister to fake the seat belt switches?...there are four in the rear of my 2 dr. 2 on the female sides of the belts buckle and two on the seat belt winder itself.
Probably a long shot.
TX-Hans
Although getting far astray from the topic of the fog light switch in this thread, if you are looking to turn off the seatbelt reminder for specific seats, there are ways to do that using Forscan and also shortcut ways to do it outside of Forscan.
https://www.bronco6g.com/forum/thre...k-sport-mode-chimes-seatbelts-and-more.28489/
https://www.bronco6g.com/forum/threads/how-to-disable-the-seatbelt-chime-less-than-2-minutes.42934/
https://www.bronco6g.com/forum/thre...hacks-im-talking-to-you-seatbelt-chime.42914/
BigMeatsBronco
Allan
2021 FE 2 door
This came from another thread. I did this for the driver seat but its supposed to work for all seats. Give it a shot
I'll try this, but I think the system runs a self check and checks the resistance in the micro switches in the seat belts....once the switches are removed then I get a restrains with seat belt and airbags in icon warning light, this is different than the "put your seat belt on "light.
It's the yellow one I'm trying to omit.
Ford Bronco Factory Fog Light Switch 20220429_212934
