Exploded Steering Rack
bendover
bendover
BMW M2, Bronco Badlands
It must be a programming or certification issue. Mechanically I think they're all the same.
I'm sure FDRS would program it.
zuke
Stafford VA
Why don't they make it for 2021-2023 4Dr Bronco w/o Sasquatch? They make it for every other Bronco.
Because it's the only setup that they haven't been able to steal all the various specs from an existing setup designed by Ford, (not Ford Performance) Which as far as I know, Ford performance doesn't know how to do.
When the rack is changed with the Procal, I'm guessing it also changes settings in other modules such as ABS and AWD to include steering angles, for sasquatch package vehicles, they can just use the settings Ford developed for the Wildtrak with HOS$ 3.0.
To allow all the other ones, they'd have to program for multiple tire sizes and steering angles for each trim, with differing wheel and tire sizes, M190 front axles, and 2 different transfer cases.
So really, they have to account for a lot of different possibilities to offer ProCal programming for 'All Others'.
When programming with FDRS and a VIN swap, we're skipping all those other settings, and running our original configurations when we swap the VIN back, so we're accepting a liability that Ford performance can't accept as a corporate entity. Honestly I'm not sure how they got the 'all 2 doors' past the corporate legal department.
The truth of the matter for us as final owners however is we've likely all broken those settings anyway, by putting on an aftermarket lift on that changes all the same geometry. It seems unlikely a stock height big bend owner is going to put this upgrade in without putting on a lift and larger tires too merit a need for the heavier rack.
As a result, I just don't think Ford performance see much need for the upgrade for 'All Others'.
If you have an 'all others' just buy a stock 3.0 rack or Ford performance rack based on best availability and price, and plan to use FDRS with an alternate VIN to program it. You aren't really losing anything that matters doing it that way, and your life will be easier getting it in.
CalvinT
Calvin
Phoenix, AZ
2023 Badlands came with a Dana M210 axle, same as Wildtrack. The only real difference between the two is Wildtrack came with SAS as standard.
The only real difference is 1 inch lift.
Ford is basically saying that if you have a 2021-2023 4 door Bronco without a lift, you can't have the advanced steering rack. They'll give it to anyone with a 2 door no matter which front axle or lift. Makes no sense. 4 door Broncos must be lifted or no advanced steering rack.
I think some accounting or marketing "genius" decided there's not enough market to pay for developing the parameters. Same process that accounts for other feature mixes people comment about on here.
zuke
Stafford VA
It does surprise me they never came out with a setup for the 4 door Badlands, it seems like pretty much everyone with one would want the upgrade, but it does require settings that may not be a match for the 2024 Badlands because of some other change that happened to all 2024 trims..
bendover
bendover
UPDATE:
The dealership replaced the steering rack. After inspecting the damage, they determined that the Ford Performance skid plate bracket is a piece of shit and snapped off the frame rail and was thrown into the steering rack. (given)
I reached out to Ford Performance before I got the dealer involved and was told they would forward the photos to their engineering team for review. After that email, communication stopped and I never received any follow-up.
for anyone who parties hard, the raptor skid plate is definitely a hard pass. I'll probably end up just welding the FMI lower control arm gussets in and let the stock skid eat.
