Electrical issue?
jeff hunter
jeff
austin, texas
bronco wildtrak, 4-door
Left my '22 Wildtrak in the garage for a week, when I came back, the ignition was unresponsive and several of the function warnings scrolled across the dashboard screen. I disconnected the battery and reconnected it with no change to the problem. Anyone else ever have this issue?
jeff hunter
jeff
austin, texas
All lights, A/C, screens, etc. work fine.
jeff hunter
jeff
austin, texas
Battery level indicator on dash board shows 12.1 volts.
Navyicman
Tim
Ct USA
2022 BS Big Bend Area 51
I'd check the battery anyway. Your stuff may work, but not the ignition. Also check all battery connections and grounds, plus look at your fuses.
What does the digital battery guage say for voltage?
Nevermind I see your post
jeff hunter
jeff
austin, texas
OK, will do that. Thanks for the suggestions.
jeff hunter
jeff
austin, texas
Thanks Felix. Ford service tech suggested I jump it off and that might at least get it started, so I'm going to try that next.
userdude
Denton, TX
2023 2dr Badsquatch
Heat can kill a battery. I've had car batteries go bad in August in Texas maybe three times last 20 years? Once couple years back, Autozone replaced it because it was only two years old.
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
Charge the battery up, you’ll be good to go.
Let me guess, ABS, Traction, Low Battery and maybe even Powertrain faults? It might take a day or two for the system to be completely happy (not go into battery saver mode immediately on shut down).
jeff hunter
jeff
austin, texas
OK. All those function messages are exactly what I'm seeing. Hooking up a battery charger is the next thing I'll try. So far, nothing I've tried has had any effect at all.
rpaluch1
Rudy
Tecumseh Mi
Ford Bronco
I have a 22 OBX and left it in my garage for 10 days while we where on a trip. Came home and went to start the vehicle and it as dead. No lights no noises just dead. I jump started it and then came the error parade. Finally after a fully charged battery and most faults reset them selves but I had 2 that didn’t. ABS and it was locked in 4 wheel. I had to have the dealer reset those. Have the dealer check it just to be safe. It’s warranty and is a short visit.
tock13
Tony
WA State
Mazda, 66 Honda CT90, ā€˜94 Toyota Xtra cab
I have read several posts of the battery draining after 8 or 10 days. So is it a bad idea to leave a bronco at the airport or parked somewhere if you go on a trip for a week or two and let it sit?
I know I’m in the minority here but I’m am no fan of all the tech on these things that need power 24/7, it’s quite annoying. Is the only way to shut off the parasitic draw to install a battery isolator switch and completely kill the connection to the Bronco?
Maybe that’s the key to not coming back to a dead bronco after 10 days?
BAUS67
redneck
Central PA
...........or just disconnect the negative battery cable. It only takes a 10MM wrench and about 30 seconds of time. 😁
tock13
Tony
WA State
I like that idea!!! my last off-roader had a carb and no computer and ran fine with a low battery so this beast is a new world for me.
If I were to disconnect the battery for say 3 weeks. Is there anything that is going to have issues with that in the Broncos computer brain? it doesn’t try to do status checks of it’s systems on some schedule does it?
