DV8 Offroad | Air Compressor Mount & Storage Box
DV8offroad
Riverside, California
dv8offroad.com
Bronco's & Jeep's
2021-2023 FORD BRONCO | AIR COMPRESSOR MOUNT & STORAGE BOX
Our Air Compressor Mount & Storage Box provides a convenient and discreet mounting location for your ARB single or twin on-board air system compressor. With a focus on functionality and ease of use, our box is equipped with a rubber grommet and access hole, providing effortless wire management access for the compressor. The provided heat shielding material effectively insulates the container from heat radiating from the exhaust and external roadway temperatures, ensuring the longevity and reliability of your air compressor. The water-resistant skin that covers the ARB mounting holes offers protection against the elements, allowing you to tackle any terrain with confidence. This system streamlines the process of airing up and down, allowing you to enjoy your off-road adventures without the unnecessary hassle of an external compressor.
Our larger box is specifically designed to replace the smaller OEM box, ensuring a simple installation process using factory mounting points. Not only does it serve as a secure and stable mount for your compressor, but it also offers an additional storage compartment for your convenience. This spacious compartment is perfect for stowing air hoses, recovery equipment, tools, and more, keeping your essential gear within easy reach whenever you need it.
Check it out here: https://dv8offroad.com/products/bronco-air-compressor-mount-storage
Ford Bronco DV8 Offroad | Air Compressor Mount & Storage Box pressor-Mount-and-Storage-Box_Installed-7_1051x700
Ford Bronco DV8 Offroad | Air Compressor Mount & Storage Box pressor-Mount-and-Storage-Box_Installed-4_1051x700
Ford Bronco DV8 Offroad | Air Compressor Mount & Storage Box pressor-Mount-and-Storage-Box_Installed-3_1051x700
Ford Bronco DV8 Offroad | Air Compressor Mount & Storage Box pressor-Mount-and-Storage-Box_Installed-9_1051x700
Key Features:
  • Designed for ARB Single or Twin Air Compressors
  • Hides Air Compressor in Convenient Location
  • Utilizes Factory Mounting Location
  • Access & Rubber Grommet for Wiring Solutions
  • Provides Additional Storage Larger than Factory Box
  • Heat Shield to Reduce Temperatures from Exhaust/Exterior
  • Water Resistant Skin for ARB Mounting Holes
  • Drain Plugs for Use as a Small Day Cooler
Visit https://dv8offroad.com/pages/ford-bronco-bumpers-and-accessories to shop all of our Ford Bronco Parts and Accessories.
Plus... use code "ForumMember" at checkout for 10% off!
cr117
PNW
Bronco, EV6
Are you able to provide interior dimensions of the storage area?
DV8offroad
DV8offroad
dv8offroad.com
Bronco's & Jeep's
Sorry for the delayed response, but here are some poorly illustrated dimensions lol
Ford Bronco DV8 Offroad | Air Compressor Mount & Storage Box 1689976114970
Tor148
Tor
Cape May Court House, NJ
23 Braptor Bk, 21 FE RR, 15 F250,
Key Features:
This is great and what I was looking for but then i read NOT FOR BRONCO RAPTOR.
Why no love for the braptor?
cr117
PNW
Bronco, EV6
Awesome, thanks! I’m assuming the one on the right is the stock container?
IwannaGOfast
Jon
Brea, CA
2021 4 door Badlands, 1991 Ranger Long Travel, 2014 Cruze Commuter
I imagine some people might be interested in this without a compressor just for the added storage.
m_grovs
Pagosa Springs, CO
2021 BaseSquatch 4 Door
I was thinking it could be a good location to mount stereo amps.
cr117
PNW
Bronco, EV6
Mikerider
Washington
Raptor, Ranger, Mustang, Focus, Explorer
Nice! happy to see a larger storage solution! this is on my list for sure.
Any details on routing wires and air lines to/from the compressor?
ScLeCo
Springfield
Charger Hellcat
I guess those would be good if you need to air up and never have any stuff in the back of your vehicle. Otherwise unpacking just to be able to access the air compressor seems like a major PITA.
IwannaGOfast
Jon
Brea, CA
I would think you would mount this in the storage and run the outlet outside of the compartment somewhere. Then wire it to a switch and you wouldn’t have to access that compartment at all.
@DV8offroad
Is anyone currently running this setup? Any suggestions as to where to run the outlet?
Blaylock1988
Colorado Springs
2021 Ford Bronco, 2004 Volkswagen R32
Do you know if this is designed to open the floor lid while operating the compressor? I saw someone using this box with a remote air outlet, so it stayed closed while running. I'd like to do this as well but I'm concerned about the operating temperatures in the box.
SierraBronco
@DV8offroad
Not using this box but I did mount a compressor in that location. Outlets are in a couple locations.
Ford Bronco DV8 Offroad | Air Compressor Mount & Storage Box IMG_2740
Ford Bronco DV8 Offroad | Air Compressor Mount & Storage Box IMG_1355
