- Mar 17, 2022
- 83
- 224
- 400
- Riverside, California
- Website
- dv8offroad.com
- Bronco's & Jeep's
- Badlands
2021-2023 FORD BRONCO | AIR COMPRESSOR MOUNT & STORAGE BOX
Our Air Compressor Mount & Storage Box provides a convenient and discreet mounting location for your ARB single or twin on-board air system compressor. With a focus on functionality and ease of use, our box is equipped with a rubber grommet and access hole, providing effortless wire management access for the compressor. The provided heat shielding material effectively insulates the container from heat radiating from the exhaust and external roadway temperatures, ensuring the longevity and reliability of your air compressor. The water-resistant skin that covers the ARB mounting holes offers protection against the elements, allowing you to tackle any terrain with confidence. This system streamlines the process of airing up and down, allowing you to enjoy your off-road adventures without the unnecessary hassle of an external compressor.
Our larger box is specifically designed to replace the smaller OEM box, ensuring a simple installation process using factory mounting points. Not only does it serve as a secure and stable mount for your compressor, but it also offers an additional storage compartment for your convenience. This spacious compartment is perfect for stowing air hoses, recovery equipment, tools, and more, keeping your essential gear within easy reach whenever you need it.
Check it out here: https://dv8offroad.com/products/bronco-air-compressor-mount-storage
Key Features:
- Designed for ARB Single or Twin Air Compressors
- Hides Air Compressor in Convenient Location
- Utilizes Factory Mounting Location
- Access & Rubber Grommet for Wiring Solutions
- Provides Additional Storage Larger than Factory Box
- Heat Shield to Reduce Temperatures from Exhaust/Exterior
- Water Resistant Skin for ARB Mounting Holes
- Drain Plugs for Use as a Small Day Cooler
Visit https://dv8offroad.com/pages/ford-bronco-bumpers-and-accessories to shop all of our Ford Bronco Parts and Accessories.
Plus... use code "ForumMember" at checkout for 10% off!
