DONE! I have re-drilled rear shock mount 2” higher, =more clearance and 2” lift.
BigMeatsBronco
BigMeatsBronco
Allan
2021 FE 2 door
@BigMeatsBronco and @Parcsalooc Nice, can you share which exact lift components are you each running up front?
I'm at about 1.75-2" lift above Sasquatch...
I used the common 3/4 aluminum spacer above the coilovers, also a 3/8 spacer on lower shock mount (I'm removing these soon)
took shocks apart and trimmed ALOT off bump stops and reinstalled. dropped front diff 1.5" to keep the CVs the same angle as OEM. I have 12"+ front travel using OEM coilovers.
badbronc4x4
Cory
Scottsdale, AZ
2022 Ford Bronco Badlands Sasquatch
@BigMeatsBronco I'm very interested in your Rear Shock Mount adjustment and Front Diff Drop to either find a shop in AZ that would be willing to do both for me. As much as I would love to do this myself I think I just like the piece of mind of someone that has a little more technician experience then myself. I can def do alot of basic and easier stuff but something like this might feel more comfortable with someone of expertise in modifications.
RubyRedGT
Greg
Pittsboro, NC
21 Bronco. Sold the 1968 and 2015 mustang GTs
Very nice @BigMeatsBronco
How did you drop the front diff? Did you just purchase or fabricate spacers? If so what size? Thanks!
cbrownabq
Littleton, CO
Dodge 2500 diesel
BUMP
Doing this tomorrow. It’s surprising how little info is out there. Anyways, this is going to be matched up front with my Broncbuster 1 1/2 perch collar lift and swaybar removed. Still have rear sway bar.
RubyRedGT
Greg
Pittsboro, NC
BUMP
Doing this tomorrow. It’s surprising how little info is out there. …
Nice 👍 How’d it go? Do you have pics or additional suggestions. I’ll be doing this very soon.
Mikerider
Washington
Raptor, Ranger, Mustang, Focus, Explorer
I like this mod and have been thinking of ordering a set of the Barnes 4wd rear shock mounts and sectioning them higher. I like the thicker steel and brace. Either that or make my own mount.
https://barnes4wd.com/products/bronco-rear-axle-strut-mount
Great job on the mod and it looks like a great way to gain some lift and ground clearance with minimal compromise.
Noremac
Arkansas
2021 Bronco Badlands Sasquatch
Reviving an old thread... I completed this on my badlands last night and have a lot of nay-sayers lol. ooh you are ruining the warranty... totally unsafe.. blah blah blah.
I had the idea a few months back, but never acted upon it.. searched the internet and found your thread and solidified my choice. Thanks for pioneering so many cool ideas! Im letting it settle for a few days, then chopping off the excess for the additional ground clearance.
Before with a 2" front level (perception of being squatted, yet rear is 1/4 to 1/2" taller than front):
Ford Bronco DONE! I have re-drilled rear shock mount 2” higher, =more clearance  and 2” lift. 1709742962767
After (only went for about 1 3/4" increase in height):
Ford Bronco DONE! I have re-drilled rear shock mount 2” higher, =more clearance  and 2” lift. 1709743058719
Ford Bronco DONE! I have re-drilled rear shock mount 2” higher, =more clearance  and 2” lift. 1709743046375
BigMeatsBronco
BigMeatsBronco
Allan
2021 FE 2 door
glad it worked out for you.
