Bronco Rear Shock Mount - AKA Rock Catcher
Az_Squatch_Bronco
Shawn
Tucson
Bronco Badlands w/ sasquatch pkg - Carbonized Grey
So I found out the rear shock mount at the axle is very attracted to rocks. 😄 🤣
I "tweaked" the drivers side one a bit...it kissed rocks on a few occasions....admittedly it my fault for forcing the Bronco over a Rock on the last obstacle of the day....so I ordered some new mounts from Barnes 4WD.
I plan to take the coil over off this week, Iam thinking it's bent as well.
Does it look like it will need to be replaced...I didn't install them so Iam not sure if the bolt is just bent or those spacers are part of the shock....they are Fabtech Coil Overs.
Ford Bronco Bronco Rear Shock Mount - AKA Rock Catcher 20230903_153606
Ford Bronco Bronco Rear Shock Mount - AKA Rock Catcher 20230903_160831
BigMeatsBronco
Allan
2021 FE 2 door
Damn those look trashed! did you lunch it into a rock garden? after you straighten out and rebuild those tweaked ones, you need to chop off the lower 2.5inches and re-drill the hole 2" above the original.
this gives alot more clearance and a nearly free 2" lift as well. a win-win.
Az_Squatch_Bronco
Az_Squatch_Bronco
Shawn
Tucson
I was climbing a rock ledge but caught it on a rock coming up.
I'll have to see if the new ones are as low as the stock.
chtucker
Kirkland, WA
FJ Cruiser
I see a bunch of grinding/cutting/welding in your future….. looks like the control arm bracket and the coilover brackets are trashed
Az_Squatch_Bronco
Az_Squatch_Bronco
Shawn
Tucson
Well, some welding on each side of the new brackets. A flap disk will make short work of grinding off the old bracket.
The control arm bracket is untouched.
scotman623
Saratoga Springs NY
Chevy LT Trail boss
WOW!!! Mine are pretty banged up, but nothing like that.. I may try what @ bigmeatsbronco suggested.. Seems like that should definitely help.. Keep us posted on your fix my friend..
Fmuguira
Frank
Idaho
Jeep TJ
Wowza, that took a serious hit!! Hopefully some aftermarket solutions, besides skids, will gradually appear…. Raising shock/strut bolt/height would make great sense.
Az_Squatch_Bronco
Az_Squatch_Bronco
Shawn
Tucson
Fmuguira
Frank
Idaho
Jeep TJ
Not really sure why Ford couldn’t have engineered all those components with 3-4” more of grd clearance ….
retiredarmymp
Steven
Whitehouse, Texas
2021 Bronco Badlands Sasquatch
DV8 Rear shock skids cover both the lower shock mount and lower control arm mount. They also make great front lower A-arm skids
Ford Bronco Bronco Rear Shock Mount - AKA Rock Catcher BR6A
Ford Bronco Bronco Rear Shock Mount - AKA Rock Catcher B8
Az_Squatch_Bronco
Az_Squatch_Bronco
Shawn
Tucson
What's the thickness of those? To be honest Iam not impressed with DV8. If their armor is anything like their fender liners they are not made to last.
I will probably be buying the A arm skids, control arm skids and shock skids from Barnes 4WD.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Barnes or check out Metal Cloak
Az_Squatch_Bronco
Az_Squatch_Bronco
Shawn
Tucson
Got the new Barnes brackets in today. They are boxed on the bottom vs open like the OEM and thicker. So they should hold up a little better. I should have them installed Tuesday.
Ford Bronco Bronco Rear Shock Mount - AKA Rock Catcher 20230907_170718
Az_Squatch_Bronco
Az_Squatch_Bronco
Shawn
Tucson
Got the new shock mounts on the lower rear installed today.
I am very pleased with them.
Ford Bronco Bronco Rear Shock Mount - AKA Rock Catcher 20230911_173717
Ford Bronco Bronco Rear Shock Mount - AKA Rock Catcher 20230911_173702
