Do GOATs matter?
UniBroncorn
2022 Bronco Raptor
Hi all, maybe a n00b question but how much does the goat mode suspension setting one is in matter as to the durability of the vehicle.
Example: if I go over a speed bump at 100km/h in Sport mode, catch some air and land vs same scenario above in Baja mode.
Will the scenario above be better for the vehicle durability (no breaking stuff etc) in Baja mode since Baja mode is supposed to soften suspension to take larger hits/bumps?
Ps. Most promotional videos show Bronco catching air on dirt/sand, is doing the same on rock/asphalt worse/problematic since these are hard surfaces with no give as opposed to dirt/sand.
Thanks!
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
Yes for a Raptor
I don’t think it hurts the suspension at all, unless you’re bottoming it out, it will just handle worse and the composure of the vehicle will be worse. I wouldn’t expect to much worse, but noticeablly at least.
1st 75th ranger
jeffrey
nj
Thanks!
yes goat modes work i wheel often and its rare i go goat mode but do change in and out of trac control when needed ...goat will not changes suspension firmness or travel on std broncos
BlueBronco
DFW
If you go off-roading and attempting to catch air at 60mph+, 1. wear your seat belt, and 2. be sure to have someone video the resulting carnage.
Canyon Coolers
Flagstaff
canyoncoolers.com
73 Bronco, Dodge 2500, Sprinter Van
GOAT modes in a raptor will change the suspension, in our mere mortal Bronco's and yours it will also change things like Turbo spooling and allow for various degrees of wheel slip, shift points and steering input if I'm not mistaken. Your adjusting an entire system, so no one point in time is likely to matter, but over time of course it will create or protect you from various driveline stresses and alter performance.
RobWTX
Rob
Raptor model can take it pretty well, at least on dirt.
Bschurr
NY
I don’t recall where I picked this up but it’s from “back in the day” (and pre-Raptor)
This provides an overview of the GOAT modes & their changes to vehicle settings.
Ford Bronco Do GOATs matter? IMG_6366
UniBroncorn
UniBroncorn
2022 Bronco Raptor
I went to Fox 🦊 website and based on their live valve technology explanation I think that GOAT does nothing to actual suspension as it self adjusts. I think GOAT just changes the parameters that above table indicates.
Any one else with more concrete explanation/proof please chime in.
Durangatan
Marty
Durango, CO
Bronco, A6 Avant, TTRS, SQ5
Thanks!
I hope that I am misunderstanding your intention.
Speed bumps usually reside in residential areas - areas with low speed limits because pedestrians are around.
If you are doing 100km/h in such an environment that qualifies you for some sort of douche-bag award.
JohnnyBronco
Pennsylania
X4
I knew my steering changes in Sport and the chart reinforces that feeling
Acadist
WA
2023 BadSquatch
Goat modes are the cheat sheets for off roading with all the electronics. You can change it all manually, but why???
