Ditch Lights - Aiming
B-rad351
Brad
WV
2024 Bronco
I installed ditch lights on my ‘24 Badlands and want your opinion on aiming them. Right now, they are aimed about 45 degrees and downward from straight ahead. I have seen pictures of other Broncos having them aimed straight ahead and level.
Thanks
Ford Bronco Ditch Lights - Aiming IMG_5728
Deadpool392
New Bern, NC
2025 Marsh Gray Bronco Raptor, 2020 Gator JTR (retired)
There is no “right” way to aim them, they should be aimed however you want them to provide lighting. I have mine angled outboard and slightly down so that they provide lighting to the sides and edge of the road.
CalvinT
Calvin
Phoenix, AZ
You don't know if the other Bronco owners were more interested in how well they could see or how they looked.
Go someplace dark and make adjustments until you can see what you want to see. That's how I'm going to aim mine.
Gassyjack
United States
Thanks
Mine are aimed like yours. I want to see a wider lighted view when turning and what’s off to the side when cruising at night.
crzyhawk
Virgina
2024 Bronco, 2008 Mustang
I don't have ditch lights, so YMMV. Most of the ones I see in videos are angled to the side. I assume they are called ditch lights because they are supposed to illuminate the ditches, which if all is according to plan, should be along the sides. Forward illumination, I'd think would be better served by centrally located lights.
Now, I will say that when they are mounted and not doing anything the look a bit better to me pointed straight forward. My OCD likes that. I'd also think that creates a bit of glare on my hood. So, I've pretty much concluded that people who face them forward are doing it for looks rather than performance.
Squirrel13
Brad
KY
I have my A pillar LP4s aimed straight ahead and slightly down. They do a fantastic job in down range and the side emitters light the sides. For a dedicated ditch light I mounted S1s with the trail lens on the crash bars at 40-45* angles.
Ford Bronco Ditch Lights - Aiming IMG_3523
Ford Bronco Ditch Lights - Aiming IMG_3520
Ford Bronco Ditch Lights - Aiming IMG_3353
B-rad351
B-rad351
Brad
WV
2024 Bronco
Great idea! Thanks for sharing
SierraBronco
Mine aren’t even hooked up
CalvinT
Calvin
Phoenix, AZ
Mine aren't either, yet. Will do it Monday or Tuesday when crimp connectors arrive. I didn't like the ones available locally.
SierraBronco
Gonna order moar lights and just use bluetooth as a means of power. Way easier than running wires. Time to win some car shows.
CalvinT
Calvin
Phoenix, AZ
Wiring mine to upfitter switches.
Let us know which car shows you enter.
CalvinT
Calvin
Phoenix, AZ
kodiakisland
Arkansas
Aim them where YOU need them. Doesn't matter where someone else has theirs aimed.
If they are just for looks, who gives a crap where they are aimed.
