Ditch lights question
Haunteddude
Illinois
2023 bronco, 2021 Ram 1500 Limited
Yes sir. Thats what they are. so I have the wrong ones....... back to the drawing board lol
Thanks
Haunteddude
Illinois
Looks like my only option are the rigid lights
Haunteddude
Illinois
What happens if you put power to both red and yellow and ground the black?
No amber only white. Amber only when I hit the mode switch that was supplied with the lights
swooshdave
Portland, Oregon
Mustang
Ah, I bet if you hook up the red to power and ground the yellow it will work. I think the switch is basically switching the grounds.
Haunteddude
Illinois
Far out. I'll try that tonight Thanks
TXBronco72
Magnolia, Tx
F250 / ‘23 BRaptor
If it were me, I would just cut off the relay, switch, etc (see red X below) and rewire from that point. I see a 4th (white) wire between the relay and controller that must be what is telling the relay what mode has been selected.
Ford Bronco Ditch lights question Picture1
Haunteddude
Illinois
That's exactly what I did. but the yellow light does not work
swooshdave
Portland, Oregon
Mustang
It would really help to know how the relay was wired. If you pull the plug off the relay we can see the pin config and hopefully a diagram.
But weren't you sending these back because you just wanted yellow running lights and not full blown fog lights?
Haunteddude
Illinois
no idea what this means lol
Ford Bronco Ditch lights question 20240122_130524 (1)
Lordsandy
James
MA
Black to ground.
Red to aux switch for white lights.
Yellow to 2nd aux switch to backlight or tie into daylight ir parking light circuit wiring.
BUCKIN6VA
Rob
Northern VA
www.youtube.com
'12 911 GTS, '25 Model X
Black to ground.
FWIW This is how my bumper fog lights are wired with no relay in between.
Luckylat
RI
1999 Expedition, 2013 VW Wagon, 2023 Wildtrak
Diode Dynamics, while a little pricier, provide quality amber backlit pods. Their lumens output is output vs. other is incredible.
I also hooked all of my pods to AUX 5 as I wanted the flexibility as to when to use them. I suggest reaching out to the team at 4x4TruckLeds. They know their stuff, are unbiased have a great selection/inventory. Very helpful with their customer support if needed.
Ford Bronco Ditch lights question JS Bronco - DD Amber Back lights
Ford Bronco Ditch lights question JS Bronco - DD lights
