Developing a HATE for my Load Range E Tires
22Badskwatch
Sacramento, CA
2022 Badlands Sasquatch
I have been running 40 psi. I wasn't comfortable any less. 32psi? Seems really low but at this point, it is give it a shot or shell out $1500 for new rubber...
holy cow, 40??? I drive on 32PSI all day long with my stock Sasquatch tires ... makes a huge difference
Rjacks258
Randy
Punta Gorda, FL
2022 Ford Bronco, 2019 Ford F250, 2009 Ford Ranger
‘Cuz ‘E’ range tires do not belong on small trucks. Period.
tractorcrusher
Curtis
DFW, TX
Jkoren12345
Jkor
US
2 dr 2022 Bronco
I put these Terra Grappler G2's on about 10,000 miles ago, and I am ready to get rid of them. Love the look, offroad they are great, but this thing doesn't ride anywhere close to as good as my F150 did on the road, and I am thinking it is the E rating on the tires. Any input/advice would be greatly appreciated. It is a Badlands Non-Sas. Thanks.
I've got 33in Terra Grapplers on stock Outer Banks wheels rolling at 34psi. I don't know anything different cuz they were put on before l took delivery-that said, they seem firm but over-all my 2dr rides pretty nice/smooth. Definitely lower your psi-at 34 psi my tires are wearing nicely...
dankeller13
dankeller13
Dan
Souderton, PA
I lowered the psi down to 30, it is a huge improvement. Hitting potholes is not near as jarring as it was previously, and my tailgate rattle is quite a bit quieter! I appreciate all the suggestions/advice!
rtazz17
Connecticut
2022 Ford bronco big bend
way over pressurized. I run 24 psi on my load e tires. Rides nice. If I was at 40 I would be shattering my teeth.
rguest3
Raymond
Florida and Virginia
F-350, F-450, 23 Bronco, 24 Raptor, (2) 77 Broncos
An "E" rated tire is way overkill for the fairly lite weight Bronco.
I have 37s on my 4-Door that are "E" rated Toyo ATIIIs. The front corners on the Bronco weight average 1470 pounds each. This is way less than the capacity of the tire.
I run 30/28 and it is quite comfortable. At this PSI there is also a complete tire contact patch on the road. Why would I put any more air in the tires? This is plenty of PSI even if my Bronco was fully loaded.
dgorsett
colorado
F250, Mustang, Explorer
Or until you get tired of puncturing tires by driving over a Cholla Spine, or a twig, or a sharp piece of scree.
P rated tires belong on pavement. I don't even live on a paved road. If they made C rated tires for the Mustang I'd use them.
Load Range E for the win. I picked up a ball of Cholla in AZ last week, midway on a side wall on my Falken LRE's. A week later and no air loss.
2112
Fox island
F350 GT500’s FGT MACH I Z8
Ran E-rated at 80 PSI on our expedition. Ran fine. I like feeling the road, hate a squishy ride.
Squishy tires make a vehicle corner like crap too.
+1
Well, not the 80psi, but everything else
One who waits long time
Jack
Oregon
F250 Diesel, Road Glide Ultra, Fat Boy, Beta 500 R
I went with C rated KO2's in 37s. Ride is quieter than stock, stiffness is about the same but cornering is worse.
half-fast
PA
F150, Bronco (2dr)
I had Continental Es on my F150 to accommodate Raptor wheels. Lasted less than 7500mi.s before they went on Ebay. Never again.
thatch11b
Philly
2022 Ford Bronco 4 DR Softtop
Definitely lower the PSI. You should run in the 30’s. Experiment and see where you like it. I run mine at 33 psi. Still doesn’t ride like a “c” but it’s bearable.
GmaninAZ
Gary
AZ
2019 Harley Davidson FLHX
Load range E are usually 8 ply and for pickup trucks meant to haul heavy loads, or be capable of doing so, which you will not be doing in the Bronco. Factory tires are C load rated. You are running too high a pressure at 40 psi, why? They are not 45 or 35 aspect ratio tires and have a lot of volume and a tall sidewall where 34 to 36 psi will be more than enough. As you go down the highway the pressures will increase 2 to 6 psi depending on ambient temps over whatever you start out with. I feel your pain and it must ride like a lumber wagon..... Go back to the 285/70 R17s in a C rated tire. Are your wheels 8.5" in width? The 315s should be on a 9.5" wide wheel; yous look too narrow for the tire section width.
