Damage while using winch on improperly installed Rough Country High Mount
Status
Not open for further replies.
Tex
Cliff
San Angelo
Made from Maraging 350, right?
Right?
Bronkers
Ben
Las Vegas, NV
2022 2dr Bronco
I'm starting to think about that intercooler that mounts higher to set the winch between the frame rails then build my own bumpers front and rear. Getting real tired of banging my rear tow hooks off rocks too.
Maybe even bumpers I can sell...🤔
Ford Bronco Damage while using winch on improperly installed Rough Country High Mount 20230507_173811
Mlarv
TN
Oooh baby
I am sort of lost on where these go. I have not taken my bumper off yet so I am trying to figure out before I pull the trigger on the RC high mount what I will need to make it better and safer to use.
Also I keep seeing reference to LOBO but when I look them up I can't find a website. If you are going to be selling these, or need someone to test the out I am in for a set.
Deleted User 5719102
Who's
On a Lake
22 2dr
Who's
On a Lake
22 2dr
That is likely the best plan, something that centers the pull within the frame and also doesn’t block the front camera would be awesome. I’m not super excited about replacing the intercooler due to potential warranty implications later.
I like the look of the cradle behind the Lobo WNC winch bumper and it doesn’t require moving the intercooler, but I don’t care for the aesthetics of the outer shell and my new in box M-8000S wouldn’t fit. I’m not sure if their cradle triangulates to somewhere beyond the frame horns. Something like this cradle that could keep the mod bumper would be interesting.
Ford Bronco Damage while using winch on improperly installed Rough Country High Mount 453b5365ece329de12ec4d0fe8454077
Tex
Cliff
San Angelo
I've been eyeballing the RC bumper, and I think with the high mount IC and radar relocation, coupled with a similar winch mount, that IC intake our RC bumper has could be converted to work just like that. You'd get a (mostly) hidden winch that doesn't affect clearance at all, potentially with the ability to reach the freespool lever, as well as pulling from the center of the frame. It's just potentially a bit limited with the size of the winch you can mount.
RockyBalboa
CO
'22 2-Door BadSquatch, '21 Mach-E GTPE, '13 F-150
Oooh baby
That looks proper. Do the bolt holes match up to the LOD bolt holes? (So I could remove the LOD brackets and swap these on when you start selling them)
Tricky Dick
Dick
PNW
www.TD-Distributing.com
They sure do.
Who's
On a Lake
22 2dr
BroncoAZ
Mitch
What would make this a super model of the year is if it had the same dog ears at the bottom as is the top.
Agreed, but at some point making the frame horns indestructible just pushes things to the next weakest point. The accordion section of the frame becomes the next weak point. On the Bronco5G Autofab sold a kit to plate the accordion section. I don’t think most here would want to potentially mess with the airbag calibrations by making that mod.
Ford Bronco Damage while using winch on improperly installed Rough Country High Mount IMG_5759
MNBronc
Lutsen MN
2022 Bronco
Well if you read the whole thread you wont be lost.
Link is in post #8
Status
