Damage while using winch on improperly installed Rough Country High Mount
Status
Not open for further replies.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Wow ok. That’s concerning. I bought high grade washers and nuts (better than what LOD supplied) to go with factory bolts, but chose to use the factory nut plates as I figured that would give more surface area than 1.25” washers. But it’s easy enough to swap the plate with nuts/washers.
Ford Bronco Damage while using winch on improperly installed Rough Country High Mount PXL_20230415_212015803
RockyBalboa
CO
'22 2-Door BadSquatch, '21 Mach-E GTPE, '13 F-150
I discarded that nut plate and went with some thicc fender washers behind the new nuts.
da_jokker
Jeep Wrangler JKUR
All this talk about nut plates had me wondering what I did with mine. I have the BAMF winch bumper And I don't remember keeping these.
Sure enough I looked at my garage in those nut plates are laying on top of the factory bumper. The BAMF has a solid flat metal plate (aka the bumper) that uses the factory holes but with huge grade 8 bolts, washers, and nuts.
I may still get something like the LOD but the jury is still out.
Hashlak
UAE
Bronco Sasquatch, Porsche GT3RS, Honda CBR1000RR
Just to update on my car after the hard pull.
We removed the front bumper and turns out the frame horn (circled in red) was slightly bent forward and to the side.
Ford Bronco Damage while using winch on improperly installed Rough Country High Mount IMG_20230429_130344
Managed to straighten everything up with a few taps but it's still off by like half a centimeter 😅
Looks good tho, barely noticeable but it triggers the OCD haha.
I think I would maybe order a new part later after giving more abuse and changing to aftermarket bumper.
Ford Bronco Damage while using winch on improperly installed Rough Country High Mount IMG_20230428_191645-01
MillerAndCheeto
Robin
Calgary, AB
2 Door Cyber Orange Wildtrak Sasquatch
1. Thanks for the update - even on factory bumper a "normal" (?) recovery seems to have an affect. Yikes.
2. Sick looking ride.
Tricky Dick
Dick
PNW
At the risk of sounding like somebody else that breaks stuff then sells solutions, I'm about convinced now you're going to want reinforcements if you plan to work and play hard.
Speaking of which, I need to go work on my video about Mabett taking my dash USB idea....
Tricky Dick
Dick
PNW
Full investigation and report after I get home, but it appears I bent the mount or horns again. Came down hard on the fairlead and now the mount points upward more and the winch is smashed into the grill a bit.
RC Bronco
Kansas
the plot thickens!
Tricky Dick
Dick
PNW
The lighting wasn't great but I wanted to get something before running trails tomorrow and possibly bending it back out.
Ford Bronco Damage while using winch on improperly installed Rough Country High Mount PXL_20230504_051337117
BroncoAZ
Mitch
Wow. This is starting to make me consider one of the hidden skid plate mounts instead because they don’t depend on the frame horns. I would rather have access to the cable release and to see the cable spooling, but it seems Ford made the horns out of tissue paper.
Status
