Damage while using winch on improperly installed Rough Country High Mount
Status
Not open for further replies.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
I think the latest Ford to still have some SAE fasteners would be the 2001 5.0L Explorer. I'm unsure if the entire engine was SAE but I know the exhaust manifold studs were 3/8".
zuke
Stafford VA
The earliest American car I had that was all metric was an 86 Corvette.
I don't even have to imagine to get to '86 :)
I have International Scouts right now that have NO metric fasteners. (well, they probably do now, but they didn't when they left the factory)
I really didn't pay much attention to when US cars switched over to metric other than knowing it was gradual, through most of my life I've had a variety of both US and Import vehicles so always had both types of tools.
swooshdave
Portland, Oregon
Mustang
I assumed you were an old fart. It was @cynicalrider who was asking.
cynicalrider
NJ
First gen taco
American cars have been metric for longer than you can even imagine.
Funny part is the only American car I ever owned was an '89 Bronco when I was 17 and had 0 knowledge on how to turn a wrench. I remember working on it to try to do rust repair but was awful at it and can't remember what the fasteners were.
Hashlak
UAE
Bronco Sasquatch, Porsche GT3RS, Honda CBR1000RR
Wow, so I just read through this whole thread.
What a roller coaster ride of differing conclusions and emotions 😆
I think I may be one to join OP as a tester lol.
So yesterday morning I was out with a few friends on the dunes. Got caught in a sticky situation where my right wheel was totally submerged into the sand, belly of the car beached and left wheel lodged up against a mound/bush with steering facing to the right.
No chance to move the steering or wiggle out or back up as I was on a down hill incline.
Anyway, to cut it short.. big black GMC to the rescue with a kinetic tow rope and a heavy foot. We tied the rope to my front left factory towing point (MOD bumper) and it was at an angle so not pulling straight.
Not sure what he was thinking, but the guy floored it 🤦.
Yanked out the bronco pretty hard.
Looking at the aftermath, my front left frame horn does seem to have moved ever so slightly due to the force. I can visibly see the part of the frame horn when the bolt goes in. Whereas on the other side, it is hidden behind that plastic cover. So there has been some movement for sure. My bumper also seems a bit wonky.
Been very paranoid since then, hoping that the chassis is not bent. This thread has been extremely interesting and does give some peace of mind.
Anyway, I just thought I would add to this thread. My car has been dropped off this evening to my friends garage. He will be taking it apart in the morning and will post some pics and feedback.
Ford Bronco Damage while using winch on improperly installed Rough Country High Mount IMG_20230423_133910_582
Ford Bronco Damage while using winch on improperly installed Rough Country High Mount IMG_20230423_133941_037
Ford Bronco Damage while using winch on improperly installed Rough Country High Mount IMG-20230423-WA0017
Tricky Dick
Dick
PNW
Yeah could have gone better. :ROFLMAO:
I'd love to see your findings, hopefully it was just the faceplates that bent.
kevin.gt
Kevin
Canton, GA
this buried bronco is exactly what I was talking about when questioning whether the bumper mounting plates will hold up to recovery. we should probably wait before jumping to conclusions, but what’s the fun in that. I assume they’re only intended to be used when your frame is straight with the recovery line?
huey
kevin
Ontario & Kentucky
VW GTI VW EOS GMC Envoy Badlands Bronco
every frame / cradle we build is metric. Does not matter if it is BMW, GM, Ford, Jeep Nissan etc. Automotive is very metric
huey
kevin
Ontario & Kentucky
looking forward to watching the follow up and see how all this turns out!
MillerAndCheeto
Robin
Calgary, AB
2 Door Cyber Orange Wildtrak Sasquatch
Very much looking forward to seeing what your friend finds after pulling the bumper off. And that is definitely one STUCK Bronco.
My LoD brackets should be shipping this week (hopefully). I also got myself an angle finder, and will be getting some stock measurements before and after I do a ~1,000 lb pull on the winch to pretension the winch line onto the spool. I doubt at such a low amount of stress it will do anything, but I figured I would try to add at least another data point to this discussion before adding my brackets.
RockyBalboa
CO
'22 2-Door BadSquatch, '21 Mach-E GTPE, '13 F-150
I started installing my LOD brackets today. I ran out of time and I'll finish up over the next evening or two.
RockyBalboa
CO
Does anyone know what this slot is for in the LOD brackets? It sticks down below the bottom of the frame rail, but doesn't match up with anything.
Ford Bronco Damage while using winch on improperly installed Rough Country High Mount LOD bracket (2)
Status
