Current Coiliver Lift Options?
rguest3
Raymond
Florida and Virginia
F-350, F-450, 23 Bronco, 24 Raptor, (2) 77 Broncos
I am looking into Coil-Over Lifts for my Bronco (Whenever it gets here) and want to see what the current Lift options are. I am looking for adjustable height to install with Sasquatch Package and raise later for possible 37s. Once raised more than 2", you will also need Upper Control Arms and maybe a rear Adjustable Trac Bar.
1. - 4Wheel Parts Coil-Overs with another brand of Upper Control Arms. This lift is adjustable (1-3.5") and can accommodate up to 37" Tires. I like that it's adjustable and does Not have the Remote Reservoirs and not having to trim the plastic inner fender to mount them. Seems to be a Very solid Coil-Over for just about any lifted Bronco, unless a Race Truck.
2. - Fox Coil-Overs with another brand of Upper Control Arms - Fox is considered one of the best and a standard for others to compare to. These Coil-Overs are also adjustable and have the Remote Reservoirs. I spoke with a Fox Tech yesterday and he did not expect any available until the end of January and recommended getting on a vendors list. I then called one of the top venders he recommended and they told me 8-10 months before they expected to see any.
3. King - I have also seen these listed but are on Pre-Order as well with no definite time for availability.
4. - Fabtech / Dirt Sport - Good looking kit with Upper Control Arms and Rear Lower Links.
5. - Radflo Coil-Overs are now available - Pictured Post #54
6. - Icon has many Complete Coil-Over Systems available from Stages 1-8 depending on your needs. I ended up going with the Stage 8 and this system is Fantastic!
7. - Eibach has Coil overs and Spring replacements available.
I also want to do a Lift right the first time and not upgrade in the future.
Upper Control Arms
4Wheel Parts, Camburg, Fabtech, RPG, BDS, Icon
If there are any other Coil-Over Options please let me know and I can list them in this post.
Thank you
BlueBronco
DFW
I like my Fabtech/Dirt Logic set-up, however, I am not sure when it will be ready for market.
Ford Bronco Current Coiliver Lift Options? 1639750578588
rguest3
rguest3
Raymond
That's the one I could not remember. How did you get a set? Testing for them?
Is the Dirt Logic just sold through Fabtech or other venders as well?
I see that one of the Custom Shops likes the Dirt Logic over the 4WP too.
Kenny
Covington, KY
'18 f150, 18 gt350r, '93 mustang
I believe Evo has something in the works as well as Fun Haver/RTR. I wrote Metalcloak also and they said they have a kit in the works but they said they are not sure when it will be ready for market. I had Metalcloak in jeep jk I had and loved their products.
Steelbama
Tacoma
2003 Tacoma/2015 Mustang GT PP
Heard nothing but amazing things about them.
acetdeucy
daniel
Lincoln Corsair Lexus RX350
I am looking into Coil-Over Lifts for my Bronco (Whenever it gets here) and want to see what the current Lift options are. I am looking for adjustable height to install with Sasquatch Package and raise later for possible 37s. (currently undecided) Once raised I realize I will also need Upper Control Arms and maybe a rear Adjustable Trac Bar.
1. - 4Wheel Parts Coil-Overs with Upper Control Arms. This lift is adjustable (1-3.5") and can accommodate up to 37" Tires. I like that it's adjustable and does Not have the Remote Reservoirs and not having to trim the plastic inner fender to mount them.
2. - Fox Coil-Overs and another Brand of Upper Control Arms - Fox is considered one of the best and a standard for others to compare to. These Coil-Overs are also adjustable and have the Remote Reservoirs. I spoke with a Fox Tech yesterday and he did not expect any available until the end of January and recommended getting on a vendors list. I then called one of the top venders he recommended and they told me 8-10 months before they expected to see any.
3. King - I have also seen these listed but are on Pre-Order as well will no definite time for availability.
Upper Control Arms
4Wheel Parts, Camburg, Fabtech - Any Others?
Any recommendations on the 4Wheel Parts Coil-Overs? Who actually makes these?
Thank you
I bought a set of Fox Elite, 3" to 4.5" Coilovers, from Juggernaut Performance. At the time I ordered them, he had a bulk load of these Fox Shock (in 4-wheel sets) coming in at the end of December, with a January delivery. He doesn't charge Sales Tax on out-of-state, and shipping was free. He's easy to talk to, and he can recommend a UCA, to fit your purpose (I got the Camburg, and they come in Tube or Billet, in at about $899 and 1399, I think).
Anyhow, when you remove your regular Bronco Bilstein shocks, or the upgraded Sasquatch shocks, you're back down to 0.00", except the Badlands you are still at 0.6". So, if you add these at the 3" range, you will be about 1" taller than the factory Sasquatch (which would allow 37" tires, if you have something around a "0" offset, and you would have room to still level. Anything taller than about 1" over Sasquatch, and you will also need a new UCA.
rguest3
rguest3
Raymond
I already have the Upper Control Arms on order. As usual now-a-days everything seems to take longer.
My Bronco is supposed to be built next week and then hopefully delivered soon there after.
My parts list has already started.
ryridesmotox
Ryan
Murrieta, California
21 Bronco Black Diamond
Personally, I'm doing the fox 2.5s and some camburg or Brenthel arms. I'm also probably going to do the steering upgrade broncbudter is making... kf it's reasonably priced
Mahin2021
Coeur d Alene, Idaho
F250 TD
4WP sells fabtec dirt logic lift setup.
Losy
Long Beach, CA
Gen 1 Raptor, GL63, S7
Not sure where you got your info on KING SHOCKS.
HEAD sales rep at KING, which is near where I Live... gave me information on 4x4 shops that have King 2.5's in stock. Since i don't have my BRONCO, i ordered a pair. You can also order king's from them directly for a small discount and they are about a year out. I have a set due to arrive in August. in the off road world that probably means September... ha
Losy
Long Beach, CA
4. - Fabtech / Dirt Sport - Good looking kit with Upper Control Arms and Rear Lower Links. Same story - On Pre Order maybe for a couple months.
Upper Control Arms
Thank you
for upper's I really like RPG.... They have taken over the Raptor markets the past 10 years. Camburg if you don't go billet. BUT billet looks so good.
Before you do 4wp coilers, watch the TC Customs guy compare the FABTECH To the 4wp set up. He even noticed Fabtech is superior. I see FOX and Kings as top dogs in coilover technology.
Fabteck and ICON look very similar to FOX and King's. Just not brands I am as familiar with. Seems like FOX 2.5's are available, which are great.
rguest3
rguest3
Raymond
Thank you for the info.
I did look at a couple King distributors and they were on Back order or Pre-order for the next run. king gave me the same time frame as well.
I saw the TC Customs video and he said the 4WP Coil Overs were not up to par with the Fabtech/Dirt Logic. Good to hear from someone that has actual experience with both.
I am already set with Camburg Upper Control Arms. I also have gotten on a list for the Fox Coil Overs which are said to arrive 1st quarter of next year.
Thanks
2100
If yinz know yinz know
dodge charger
This video discusses all of the coilovers coming that were seen at SEMA. Not an in depth dive, but they are including links in the description. They also discuss lifts so you may need/want to skip that to get to the coilovers.
