Current Coiliver Lift Options?
rguest3
rguest3
Raymond
Florida and Virginia
F-350, F-450, 23 Bronco, 24 Raptor, (2) 77 Broncos
I saw this. Very good.
BlueBronco
DFW
That's the one I could not remember. How did you get a set? Testing for them?
Is the Dirt Logic just sold through Fabtech or other venders as well?
I see that one of the Custom Shops likes the Dirt Logic over the 4WP too.
My Bronco was a SEMA build and the builder has a working relationship with Fabtech so he was able to get a few early sets. As mentioned, you can buy direct or from 4WP.
ROKBRNC
NorCal
2004 LJ on tons, 1970 Bronco, 2019 Tacoma TRD, 2022 Audi SQ5
First question I ask any manufacturer is “where is it made?”
If they dance around the question or say it’s made in China I remove their product from consideration.
rguest3
rguest3
Raymond
I have the Camburg Upper Control Arms and Rear Lower Links on order.
I have also decided to go with the Fox Coil-Overs.
Now, I just need my Bronco!
rguest3
rguest3
Raymond
Undecided?
What wheel Offset will work best with NO rubbing and tucked in even with the Sasquatch Fender Flare, Camburg Upper Control Arms and Fox Coil Over Suspension Lift? I want to install 37" Tires. 37x12.50R17s or 37x12.50R18s.
I am looking at a 17x8.5" Wheel with "0" Offset and a 18x9" Wheel with +18 or "0" Offset.
Which one would be best?
Update - The 18x9 with a +18 Offset works great with the 37x12.50x18s and 3" Lift
TexAZ
AZ
F-150
Camburg if you don't go billet. BUT billet looks so good.
Curious about this. What’s wrong with Camburg billet UCA’s?
Losy
Long Beach, CA
Gen 1 Raptor, GL63, S7
I was not clear, Camburg has great Billet and tube UCA's. I really like the look of the billet.
JetG
Jet
TX & FL
2018 Macan Turbo w/PP & 2016 911 Turbo Vert
I am looking for the RPG or Camburg and cant decide on which is best and if anyone has a package deal?
Tie Rod
Rear Lower Link kit
Rear Upper Lin
Upper Control arm
Fox? or?
Then bronco busters upgrade anything else that would need to be upgraded to help elevate breaking parts?
rguest3
rguest3
Raymond
Camburg has just about everything you are looking for.
RPG has some great stuff too.
JetG
Jet
TX & FL
Which is better and why? I like the idea of the RPG as it can be had in other colors as well.
rguest3
rguest3
Raymond
I don't know if one is better than the other???
Price and shipping cost may be the difference?
IwannaGOfast
Jon
Brea, CA
2021 4 door Badlands, 1991 Ranger Long Travel, 2014 Cruze Commuter
I personally have dealt with many different products from Camburg. There stuff has always top notch and they have been in the industry for quite a while
I like that they offer some of their products in both machined aluminum and powdercoated steel, both function the exact same way. For pretty much the price of aluminum upper arms you could buy their steel uppers and tubular rear trailing arms. And if color is what you are after, you can have them powdercoated any color your heart desires fairly cheap.
