Cracked on the lot.
Area51BS
Area51BS
Ron
Badlands non SAS 4dr 2.3
With the potential offer Ford is making for soft top owners. I went and looked in detail for the first time at the HT. I would like both tops. However I don’t trust it.
BroncoBoy22
Laker Land
'11 Mustang GT 5.0
No way would I spend any money on a MIC. Too high likelihood of issues. Rather get a TOR for cheaper, or Anderson Composites for the same price
Area51BS
Area51BS
Ron
I’m looking at TOR. Waiting to see how they hold up on the forums. It looks good in pics. Just not thrilled with the clamps. Look like old tackle box clamps.
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
Unfortunately these cracks have become "normal". Those who say they don't have cracks or delamination either haven't looked, haven't looked hard enough, haven't used a flash light, or haven't inspected the top at all angles in multiple light levels. I'm onto my 4th top and believe my current one is only a few weeks from showing signs of new cracks.
1986Bronco
South Texas
2021 V90 T6 Polestar, 2018 4Runner, 1990 Pao
Do you think it is just the outer layer and not structural? I'm looking a lot more intensely at Line-X which might be what it needs to stay together. There is a video somewhere of a cardboard box that got Line-X...
Rydfree
Benny
Alabama
Quality control/inspection process failure.
Does the supplier (Webasto) have people in the plant installing their tops?
Honestly it was probably fine at the plant . Mine was looked over very carefully when I picked it up but cracks appeared a couple months later . I think they have an inherent problem with the top layer process and all tops will develop cracks at some point. Some later than others obviously and most will be after the warranty period. Webasto should be running all the tops through a X-Ray line to show the cracks since most are not visible initially , but then they most likely would have a near 100% scrap rate .
Headsong
I'm just shocked, since I thought Ford had pulled that contract from Webasto after the initial fiasco. Thankfully, it led me to get the softtop!!!!! YAY!!!!!
But can't believe they're still the maker of those tops. Sad. We did not, in all fairness, ever learn if it was a Ford engineering/spec issue or a manufacturing issue.
Dude1967
Billy
2025 Ford F150 Tremor
Yup we seem to be experts on top replacements, # 4 as well.
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
Yes. I do believe it is just the outer layer and not structural. If Webasto would just make the outer layer a little thicker I think it would solve the problem.
Area51BS
Area51BS
Ron
It could be the fault of both companies. Could be Fords designing they had any part in how it’s made. Could be on the maker if they designed it or at the very least if they are going off Ford’s design, they ought to know if it will work or not. On them at that point.
BroncoBoy22
Laker Land
'11 Mustang GT 5.0
I do think line-x would do the trick if applied correctly
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
As I’ve mentioned before and in my previous post, here’s an example. This is my own Bronco (4th top). At first glance and even inspecting very closely there appear no cracks. But get a flashlight on it at a certain angle and you can see the cracks forming. This is how it all starts and then the cracks (white lines you see) will start to open up and become real hairline cracks.
Ford Bronco Cracked on the lot. IMG_5065
Ford Bronco Cracked on the lot. IMG_5063
Owl
G
Sacramento
White Wrangler JK, White Bronco Base 2Dr
Thanks for the pictures. This will definitely cause me to do inspections from time-to-time (and what to look for).
In see you are in AZ from your postings. Do you think the extreme heat might have anything to do with it? What temps have you experienced with your Bronco? Any correlations to the heat (in your opinion)?
Thanks again.
DesertMike680
Las Vegas
Lovely. I'm getting my MIC replaced under warranty later this week.
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
Thanks again.
Yes, I think it's wise to do periodic inspections. At least once a month. In the dark with your phone flashlight is the best way to find the cracks. In indirect natural daylight is the best way to see any delamination on the very top. Snakeskin (which honestly seems to be the least apparent now) can be seen in pretty much any lighting, but flashlight usually works best. You may be disappointed by doing the inspections and finding things, but at least it gives you some reaction time to file a warranty claim before it's too late. I will be out of warranty by end of the year and am on my 4th top, so I'm either going TOR or primer & paint over my OEM MIC with hopes that strengthens it up a bit.
Now to answer your question......no, I don't think the extreme AZ heat is causing it. To be honest, I think the dry climate is helping it. I haven't had any significant cracks like others, as mine have been small hairline. I think those in more humid and wet climates are somehow getting water/moisture into the top, and that is accelerating the cracking by the interior cardboard core getting wet and expanding / causing the cracking. All theory though, but I bet I'm not too far off.
