Cracked gauge cluster lense.
_lariat
Iowa
2014 F150, 2003 SVT Cobra, 1997 SVT Cobra
'23 with May 2023 build date.
Unsure if this is common or not, but my wife noted today that there was about a 3/4 inch crack in the center of the lense. Didn't know if anyone else has had this issue or not.
Local dealership has been contacted already and part is ordered. So I'm not worried about it getting fixed, but just curious if this is an oddball issue, or a common occurance.
Ford Bronco Cracked gauge cluster lense. 20240813_173715
Ford Bronco Cracked gauge cluster lense. 20240813_173730
Ford Bronco Cracked gauge cluster lense. 20240813_173735
Bschurr
NY
Why would she do that to your Bronco?
j/k - never seen or heard of this.
Baja Bronco
2Sun AZ
That is odd, never saw that. Hopefully Ford covers it.
The Badlands we drove around for Off Rodeo had cracked plastic as well, it was in a similar location but went almost all the way vertically across the instrument cluster.
One of the guides said someone put their phone there and it cracked it - somehow.
_lariat
_lariat
Iowa
I don't believe placing a phone up there would do it. (I may or may not have lost my temper one day and bounced a key fob off an old vehicles cluster before without issue.)
Reading the other post, they're all in an IDENTICAL spot. It's a $40 part. If I have to pay for it, oh well, but I may buy two if it happens again. Doing the replacement doesn't concern me. If I can find out engine swaps I can figure out a cluster lense.
DaisytheBronco
Samantha
Fort Lauderdale, FL
2022 Big Bend Bronco
Do you know the part number ? Mine is cracked too! Not sure if covered under warranty
Wichadicha
Usernamedcastle
Georgia
2025 Bronco
Exact same crack in exact same location on my daughers 23 Wildtrak. Part number if available would be great. I would rather be the one to take the dash apart before anyone else.
_lariat
_lariat
Iowa
I unfortunately don't have a P/N. It was repaired under warranty.
Ducati1098
Tonka Bronka
Duncansville
F350, V60 Polestar, 900SS, K1300S, RnineT Racer
My 21 went for probably 3 or 4 years without cracking. It's all cracked up now. Disappointing but not as disappointing as the window rattle. First things first, but I'll get to it.
