Coil failure 8k miles in.
snowcatxx87
Canada
1290SDR EVO / 701SM / Tiger 900RP / Grom / Surron
Yep, that's your problem! here is the part number for the pigtail connector. I would just wire a new one in. HU2Z-14S411-BA
Your posts and help go so far and beyond for everyone, you're a good dude. Don't know how you do it haha - people need to be able to do more for themselves than get everything given to them on a silver platter.
Cold summers
Russell
NY
2022 bronco
100% this guy cut my frustrations in half, ford owes him money. I feel like i owe him money
Ducati1098
Appreciate it. Just trying to do my part to help the community!
Silver-Bolt
Eureka, MT
Figured they would charge an arm and a leg, i think i am just over thinking it. If its as straight forward as twisting three wires together and then tapping i think ill be okay.
Don't just twist them together and tape. If possible solder the wires and use heat shrink tubing to insulate the repair. If you can't solder, use butt connectors and use heat shrink to insulate. Super easy repair. If you can't find the repair connector, you have enough wire with the damaged part to repair and reuse it.
Cold summers
Russell
NY
2022 bronco
Will do thank you! Can i use 18 gauge wire to reconnect the broken parts?
dgorsett
colorado
F250, Mustang, Explorer
1. This post reminded me to go reset the mousetrap under the hood in my motorhome.
2. @Ducati1098 is the best.
3. I'm with @Mayhem Mike. I have the driveshaft recall and was concerned about long lead time and the dealer keeping my Bronco while waiting for parts. So I went in, "strongly requested" they order parts first. They did and will replace next Wednesday.
4. Oddly, I have the 4L backup camera issue also, but the SM found no record of it for my VIN. a battle for another day.
Cold summers
Russell
NY
2022 bronco
Blue cable 16 and other are 18?
Ducati1098
Okay so i do need 18 then since the blue cable is the one completely severed
If you only need to fix that one, yes. Ideally you’ll want to use what the previous wire was. Worse case if all 3 are damaged, you can go slightly larger and use 16 on all 3. Just don’t use a smaller gauge wire
Cold summers
Russell
NY
2022 bronco
I will go 16 just to play it safe then! Thank you!
Imaginary Friend
Southern MN
A passel of Fords and a Jeep JL Rubi
This.
Solder if you can, always better long term than a crimp connection. Finish with shrink tube, just don't forget to slip the shrink tube onto the wire before making the repair....
Cold summers
Russell
NY
2022 bronco
last annoying question! How does this look to you? I peeled everything back i think i have more than enough cable.
Ford Bronco Coil failure 8k miles in. 1000024594
Ducati1098
If you have enough room, just splice the sides back together and don’t worry about ordering the new pigtail. I would fix that black/violet wire also.
It was just difficult for me to see how bad it was from the first picture.
