Cigarette lighter Plug replacement Options
contented
Karl
Central Fl
BMW M2 Competition
In spite of thinking I was careful, and yet again losing the contents of my setpower freezer/frig when someone moved it and didn’t check to make certain the cigarette lighter connection on the a/c power adapter was tight, I say enough is enough. And the plug easily comes loose from my Bluetti battery while on the road also. IMHO is a poor system/method of connection. Can anyone suggest a tighter more robust connection?
Any thoughts will be appreciated.
Lots of ways to tackle that. Least intrusive would probably be to put a whip around the cable and strap it around to something near so it stays in a bit better. But you could go all the way and replace the connector with something more robust, like a twist lock barrel connector
or something.
contented
contented
Karl
Central Fl
BMW M2 Competition
or something.
It’s all a longer story, but my precise wiring routing and use of zip ties works well until my wife gets to moving and shoving things around. I’m almost ocd neat and she’s at the other end.
The twist lock barrel connector would be a great solution on the a/c adapter and even in rear of bronco. I’ll look into them. Thanks for the suggestion.
timhood
Tim
Several
What about upgrading to the 110v plug? I run my fridge off the 110v as my first option. The outlet is low enough that it's never been an issue getting unplugged. Plus, you'll have more flexibility for other uses.
vrtical
Doug AI
GSMNP, TN
Fords
yeah that plug needs an upgrade no matter what. Honestly I used zip ties on the cords on my plugs to stabilize them as they will come lose off road. my fridge has a 2 piece power cord and that will seperate.
Chrome_Pony
Chrome
The Great Land
Blue Sea Systems 12V Twist-lock is probably the easiest replacement. Going to have to rewire both your device and the port, though.
Ford Bronco Cigarette lighter Plug replacement Options 1784136633202-15
Ford Bronco Cigarette lighter Plug replacement Options 1784136685972-6t
contented
contented
Karl
Central Fl
BMW M2 Competition
That would make things so much easier. But it is a SetPower PT45 is a 12v fridge that adapts 120 a/c down to 12v dc, so I can’t just plug it directly in 120.
Ford Bronco Cigarette lighter Plug replacement Options IMG_1039
RC Bronco
Kansas
I took a piece of cardboard from aluminum foil box and folded it over (like half and inch by quarter of an inch) and I set that at the front of the cigarette plug and slide the cable in, it fits super snug and takes considerable effort to pull out - been doing this for dozens of days and tens of thousands of miles on and offroad with absolutely no issues
akturbo
Seattle Eastside
Life is great without cigarette adapters! I swapped to SAE connectors. I don't have a pic installed, but this is the mount. Andersons would have worked, but didn't need that much power.I have one mounted to each side of the cargo area (powered by a M8RIX), left the OEM rear port alone. I made various pigtails, one is a cigarette port just in case. For the fridge I cut the fridge wire, in-line fuse and SAE connector to the port.
I also hardwired (behind the M8RIX) a couple Coolgear USB-C PD power supplies (1x100W, 2x140W), one powers the Starlink, other for charging whatever. Again, was able to ditch cigarette adapters for those items.
Ford Bronco Cigarette lighter Plug replacement Options 1784212307453-ni
Ford Bronco Cigarette lighter Plug replacement Options IMG_9175
