Check Brake System message
Num Num
Kirk
Norman Ok
Toyota....
I took a picture to show the service advisor. So far, knock on wood I haven’t had the light come back. I got the warning light and the message and it cleared within 5 minutes. The warning chime scared the crap out of me the first couple of times.
KABQ
Aaron
Albuquerque, NM
I had the same issue with my 2.7 with loss of braking (no pedal pressure until it hit the floor then locked all four tires). Here's what my dealer found, and yes it was covered under warranty.
Ford Bronco Check Brake System message image
Num Num
Kirk
Norman Ok
Toyota....
I didn’t have that problem mine thankfully was only the light. That sounds scary!
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Exact same problem I'm having. Dealer wants me to produce the problem for them but light doesn't stay on long enough to get there and I can't yet predict when the light will come on. This is driving me nuts, I'm getting impatient.
Hi there, Austin. This break system error fault concern doesn’t sound like something we want you to experience with your Bronco. Should you need further assistance, send us a PM with your VIN and the name and location of your Ford dealer and I'd be happy to look into how I can assist you on my end. To send a private message, just click on our username and select "Start Conversation".
BRBlue
Houston
Toyota Tundra
I was having the same warning in my 2.7. Brakes worked fine but the warning popped up several times. Took it to the dealer and they thought it was a grounding issue. I was using several of the factory grounding points for my accessories. After checking one with a meter it was showing a spotty connection. Cleaned polished and haven’t had an issue since.
