- Aaron
- Aug 16, 2021
- 13
- 1,219
- 2,972
- Albuquerque, NM
- '93 4Runner, '84 Vanagon, '93 Miata, '14 LittleGuy
- Base
First, I've done some searching and others have had similar issues, but in very different contexts. The vacuum line is a known issue on the 2.3, and removing the doors with the car on also causes a freakout. This is a 2.7 with the doors fitted.
Today I got caught in some construction and had to sit for about 5 minutes. A.S.S was on, so the engine was not running. After about 4 minutes I got a ton of error warnings (Service AdvancTrac, Check Brake System, Hill Start Assist Not Available, and Pre-Collision Assist Not Available) and the brake pedal vibrated several times then lost pressure. Since I was stuck in a one lane construction zone, I basically had to keep driving for several miles (at a HUGE distance from the car ahead of me) before I could pull over. When I could finally get it off the road and onto the shoulder, I had no pedal pressure and had to use almost the full pedal travel before the brakes engaged. When they eventually bit, it was full lock up. I shut it off for roughly 2 minutes, it made whole bunch of whirs and clunks, and was fine when I restarted it but the brake light on the dash was still on. When I tried to gently pull forward to test things out, it displayed that the parking brake turned off and the brake light went out. I had no problems for the rest of the drive and haven't been able to reproduce it. I'll call my dealer tomorrow, but I have a feeling they'll say "we can't reproduce the problem" and send me on my way. Any advice is greatly appreciated.
