Check 4x4 Warning
JediMcMuffin
Tommy
2026 F-150 Tremor 401A
Howdy folks, thought I'd share my experiences here, in case other folks run into similar issues. I have a 2021 4D Badlands, its been good to me up until about 34,000 miles.
What I'm experiencing right now, is similar to something that has happened to me once before early into ownership. The "Check 4x4" light message came on around the 10,000 mile mark on the way home from wheeling in Joshua Tree. When it happened that very first time, I lost transfer case control, goat mode, anti-lock brakes, cruise control, and parking sensors. The issue resolved itself at the stoplight right in front of the dealer, and that issue never returned really.
Shortly after receiving my Turn Off-Road hard top a month ago, the following weekend (super bowl sunday to be specific), the vehicle refused to start in the grocery store parking lot. The dash showed the battery was at 12.6V (should be plenty), but the starter would not even fire, the dash panels would just reboot. Thankfully I had a Gooloo booster battery with me which pushed the voltage up past 13V and the vehicle started. This happened about five or six more times over the course of a week before I took it in for service at which point they tested the battery, and it passed so I was sent home without any corrective measures done. The failure to start returned again, and this time "Check 4x4" came on with it, and the transfer case controls were offline though GOAT mode selection still worked.
I dropped the vehicle back off at the dealer. They applied updates to the PCM to address a TSB that indicated that it resolved intermittent "Check 4X4" alarms. That issue came back again, prompting me to roll up my sleeves a little, and pickup a Mongoose adapter and rent access to FDRS for a weekend. The software indicated (as Flip suggested) that a software update was necessary to the ABS module, and applying said update did actually clear the issue and restore transfer case control, though FDRS still shows an update is available the module, so I'm not really sure if it's applying it or not, and I'm not too inclined to monkey around in there too much.
One odd bit of information here, is that hooking up to a trickle charger or booster battery does bring the transfer case back online immediately, so something really is odd in that regard. I already had an appointment for my last in-warranty oil change, and to have a few recalls addressed, so I dropped it back off and was given a loaner vehicle. At this point also, they were able to get the battery to actually fail a test, so it was replaced under warranty, and all my other work: oil change, camera recall, front camera replacement under warranty was completed. I thought I was in the clear, but on the way home that Check 4x4 light came on.
Some time later tonight, I'm going to hook up to FDRS again and see what modules are flagged as needing updates to hopefully influence what the dealer does next, I don't intend to apply any update myself until this thing is stable. My biggest concern here is that I'll be up on a trail, and lose transfer case control, stranding me in a mode that either doesn't let me off a trail or let me drive a highway home.
I'm at ~34,500 miles, so not much warranty left. I'll be bringing it back to them again on Monday, later in the morning.
In case FMC is watching, here is my VIN: 1FMEE5DP7MLA86516
My vehicle is being handled where I bought it, Aaron Ford of Escondido (formerly Gosch Ford)
HP11
New Hampshire
2013 Boss 302 (sold) , 2023 Ford Bronco WildTrak
watching an interested how this will be resolved.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
@Ford Motor Company is always watching, and appreciates your proactive VIN details.
Sorry to hear about this issue - Sounds frustrating. Hopefully with that information you pull you can get somewhere with your dealership on this. Speaking of software updates, I haven't had an OTA one in a very long time on my Bronco :unsure:
TheGriffin1313
Mongo
2022 Mav
Just for curiosity sake what modifications have you done electronically to it? Any lights and or accessories added? Or just bone stock?
JediMcMuffin
JediMcMuffin
Tommy
Did the AWD module get updates. One of the DTCs that you have is related to TSB 23-2182
I think I mis-wrote above, it was the AWD module I attempted to update. To my knowledge the dealer only update the PCM. I've forwarded that bulletin to them, so hopefully that just nails the issue down.
JediMcMuffin
JediMcMuffin
Tommy
no recent wiring changes, ran fine for months prior to acting up
Warn Zeon-10S wired directly to battery
Yaesu 400-XDR wired to battery (fused)
ARB Twin wired to battery (fused) - add-a-fuse tap in fuse box makes sure it can't run without the engine running
2 x Baja LP6 Pro (aux1)
2 x DD SC2 (brake light, + aux 3 for chase light)
pillar406
Javier
www.keeseemotorcompany.com
2024 Bronco
Also if FDRS still shows updates for modules after updating it means you need to keep updating. Usually it will load the most recent updates but sometimes it has to go through the updates in order. Also make sure to charge the battery and reset the battery monitor
JediMcMuffin
JediMcMuffin
Tommy
Okay. Perhaps I’ll give it a few more tries with FDRS. Here are the notes. It looks like they did apply that TSB but because the battery tested fine at the time it was not replaced until later.
Ford Bronco Check 4x4 Warning IMG_0728
JediMcMuffin
JediMcMuffin
Tommy
Alright, so here's an update which I'm seeing as a positive: the technician is seeing the same behavior i was seeing, where the AWD module appears to agree with the software update, but never actually applies it. So they'll have it a few more days.
IIRC: the AWD module is underneath my ARB Twin Air compressor, so hopefully it doesn't need to be replaced as I'd prefer not to have unmount/remount that.
JediMcMuffin
JediMcMuffin
Tommy
Another update: The AWD module is being replaced (in other words, they couldn't figure it out). So the Bronco stays with them for a few more days.
On a funny note: My rental car is a Corolla Hybrid thats knocking out nearly 50MPG. I'm sitting here like what is this sorcery?
JediMcMuffin
JediMcMuffin
Tommy
Hopefully the last update: Issue is resolved, bronco is back home! The AWD module was replaced and updated. Lets hope it stays that way.
Caballo Verde
Adam
Bay Area
'22 OBX in Eruption Green
Thanks for sharing your experience. Just received the Check 4x4 warning and taking her in this week. Great rundown to assist them with a (hopefully) a quick diagnosis
JediMcMuffin
JediMcMuffin
Tommy
Aha! The Dreaded FTM-400!!!
It gets the job done. I did the MARS mod by myself. Having GMRS and HAM available in one radio is clutch. The FTM400 programmer will even preload all the GMRS frequencies with the proper transmit power for each.
