Case for Non-Sas
GNFITR
Auxvasse, MO
23 Non-SAS Badlands
I did not order my Bronco, I bought what was available at a local dealer after researching for a few weeks and checking out inventories. The final two came down to a Badlands with Sasquatch and one without. I ended up going with the one without simply because of the cost difference and it was definitely the right decision for me.
My intial upgrade was to purchase Sasquatch takeoffs with less than 2k miles for $1,500. Two weeks later I sold my factory Badlands wheels with BFG K02s for $1300, so that upgrade only cost $200.
When I upgraded the wheels I also added the Mabett Raptor Style Tailgate Reinforcment for $425. Some have had issues with these but I was able to install mine without any major issues. This upgrade may or may not have been needed but I wanted to make sure and now I don't have to worry if I ever go to 37's down the road.
Recently I upgraded to 6112's. The 6112 kit was on sale and I got it for $1400 delivered. I had a local tire shop I have used for years do the install and alignment for $770. I had them reuse the factory top mount, insulator and bumpstops-which despite all the erroneous information out there are the same bumpstops that come with the Sasquatch package. My Badlands only had 6K miles, all street/highway, so the factory parts were not that used. The total for the 6112's, installation , and alignment was $2170. I have seen just the assembled 6112 coilovers themselves going for more than I paid for all the parts, the install, and the alignment. I also have the factory ESCV shocks and springs for sale so whatever I get out of them will go to decrease the total cost.
So my total for upgrades that I believe are the same or better than what I would have gotten for over $5k more cost me under $2,800. I know some will say, but you only have 4.46 gears instead of 4.70s. I can live with 4.46s lol. Not a big deal to me. As a daily driver I don't mind at all.
One other comment, when I was considering what shocks to go with I did consider the Eibachs and Icons. The Icons were ruled out early on because they have to be rebuilt every ~25K or so. The Eibachs seem to be a popular choice because people like the ability to adjust them, but how many adjustments are you actually going to make? I mean once you have them set, do you plan to tweek it everyday? I looked at it a different way. I wanted to get my monies worth so I had the shop put the 6112's front and back on the highest level which is where it is now. I have a Summit Bumper and a Warn winch sitting in the garage which will go on in a week or two. I also have a set of RCI Rock Sliders on order that will add some weight. I have no plans to adjust the fronts down, but I may consider dropping the rear a slot or two depending on how much the front settles with the added weight. I like the way it sits now so I may not even change the rears unless there is a substantial drop. So being able to adjust the coilovers was not a big consideration. What was a major consideration was the 6100/6112's are a bigger 2.6 shock with a larger piston and oil capacity than the smaller 2.0's. Even if I have to remove the rears, disassemble them to adjust the level, and reinstall them it will be worth it to me to have a better stronger shock.
Photos are after install of Summit bumper, Warn Winch, RCI Rock Sliders, Ready Lift 1.25" Leveling Kit, and 37X12.50R17 BFG KO2's on Method 701 wheels.
Ford Bronco Case for Non-Sas 20241025_115803
Ford Bronco Case for Non-Sas 20241025_115834
Ford Bronco Case for Non-Sas 20241025_115851
H0pelessOpus
2015 Xterra PRO-4x
Recently I upgraded to 6112's. The 6112 kit was on sale and I got it for $1400 delivered. I had a local tire shop I have used for years do the install and alignment for $770. I had them reuse the factory top mount, insulator and bumpstops-which despite all the erroneous information out there are the same bumpstops that come with the Sasquatch package. My Badlands only had 6K miles, all street/highway, so the factory parts were not that used. The total for the 6112's, installation , and alignment was $2170. I have seen just the assembled 6112 coilovers themselves going for more than I paid for just the install and alignment. I also have the factory ESCV shocks and springs for sale so whatever I get out of them will go to decrease the total cost.
First two photos below are with the factory Bilstein ESVC shocks and the second two are after the 6112 install. Based on my measurments I saw a 2.25" increase all around with the circlip in the 6th (max) position.
Bronco looks great!
I also have a non-sas badlands. 33s are perfect for my use case. I had my eye on 6100s but ended up finding a good deal on HOSS 3.0 Fox takeoffs. Planning on stepping up to a 285/75/17 to fill out the wheel wells a bit more.
Kevin Scarbel
Everglades
Kevin
Chesapeake, VA
2024 Bronco Everglades 4dr
Everglades
Given the investment, I believe a Bronco should be "ordered", spec'd by and for the individual.
The SAS suspension is superb. It rides like a dream on-road, and performs superbly off-road. With zero negatives, I can't imagine why anyone wouldn't order SAS, except for the "Base" trim level if it was still available.
Fordified1
Bob
Mid South Texas
Curious what the difference in price between the 2 was . I also went non SAS and if memory serves saved $8k…. Which I may eventually spend in upgrades, but I can budget it in gradually. My next big upgrade is steering rack.
PWillette
Parrie
Maine
I went the no-Sas route to get the 7MT and 4.70 gearing. Sas would of added another $4,500 at the time which pretty much added up to Sas wheels/tires and wider flares.
userdude
Denton, TX
2023 2dr Badsquatch
The non-Sas BL comes with the Bilstein ESC-V's?
BigHoof
PA
Ram 2500
$8,000? It started off being $2,495 on the Badlands. My Bad sticker from Feb 2023 was $4,090. Did it really double in a years time?
PWillette
Parrie
Maine
AFAIK non-Sas and Sas same shock w/ different springs and bump stop. Sas roughly .4" higher lift but non-Sas has more articulation due to the shorter bump stop. This is in 2021...not sure now.
Fordified1
Bob
Mid South Texas
SAS package price depends on where you start. Mine is a ‘24 BD and I was trying to keep it as close to 50k as I could, and still get options that were hard to upgrade when I started specing one out in’21. If I had known the options had changed I may have ordered a different Bronco. My goal was to get 4.46 gears (or lower), rear locker, MGV and wash out flooring.
Oh I almost forgot. I did NOT want the advanced 4wd system because that seems to be the only ones having failures being flat towed. We flat tow our Bronco more miles than it is driven.
Canadian5.0
Bc
To avoid a huge write-up , time in shop , risk of a shop screwing something up
.Running around buying parts all to save a bit , no thanks , factory Sasquatch otherwise you’ll always be thinking what could have been . And 20 years from now u can still say it’s a factory Sasquatch
GNFITR
GNFITR
Auxvasse, MO
23 Non-SAS Badlands
Not accurate. The Non-Sas Badlands has the exact same dustcover/bumpstop as SAS Broncos. That erroneous myth has been perpetuated here for a long time by people who ASSumed that was the difference. But if you look you will find a couple of threads where this was proven wrong and they have the same part/part number.
MB3Z-18198-C & MB3Z-5K570-C (One is for front and one is for rear)
Also the shocks are different and the reservoir is located in a different position on the non-SAS Badlands vs Sasquatch Bilsteins.
PWillette
Parrie
Maine
Not accurate. The Non-Sas Badlands has the exact same dustcover/bumpstop as SAS Broncos. That erroneous myth has been perpetuated here for a long time by people who ASSumed that was the differnce. But if you look you will find a couple of threads where this was proven wrong and they have the same part/part number.
Also the shocks are different and the reservoir is located in a differnt postion on the non-SAS Badlands vs Sasquatch Bilsteins.
Confirmed
https://www.bronco6g.com/forum/thre...ide-lift-heights-with-wheel-tire-sizes.17719/
Fordified1
Bob
Mid South Texas
And of course it depends a lot on if someone will be doing upgrades themselves or trusting and paying someone else to do them.
Whether they like the looks of the SAS wheels tires and flairs etc etc.
Definitely different ways of thinking depending on the owner. I know the reservoirs won’t be falling off of my shocks for one thing.
