Snow for non-SAS
Bigmoose
Jon
RI
2019 Flex Ecoboost Limited
I was under the impression that using lockers on a slippery road was a mistake. Putting the Bronco on “slippery mode” does not lock the differential, does it?
Unless you are stuck in deep snow, you do not want lockers on, it makes it more dangerous. 4A does NOT enable any lockers.
Dral97
Ford Bronco, Wrangler YJ and 392, BMW 4 series
Also if you plan to make a lot of turns, I don’t think you want a locked diff. I don’t think Broncos have auto lockers, but correct me if I’m wrong.
Silver-Bolt
Bill
Eureka, MT
Tires will make or break any vehicle in the snow. Lockers are not necessarily an asset in the snow and ice.
Big Boss
Outer Heaven
Bronco Big Bend
Bronco handled Chicago area snow no problem last year on the factory Bridgestones. Didn't have any issues. Just occasionally flipped it into 4H when necessary and flipped back to 2H once I got going. In my area, we get enough snow but not enough for me to ever consider snow tires. I used to drive mustangs year round and got around fine on the all seasons they had. Just had to be careful and pay attention. Now if I was in an area that was constantly getting hammered with snow, or just much more frequent snow than I would consider snow tires.
Personally didn't care to much for slippery mode the one time I tried it in a decent snow storm. Just felt the brakes were a bit to touchy and the throttle was way to numbed down.
BroncoSarge
Jeffrey
Fort Bragg, North Carolina
2021 AMB Bronco, 2021 CO Bronco
I drove a rear wheel drive Ford Thunderbird with street tires in Cleveland for 3 years. The Bronco is way easier.
PSUTE
Western Maryland
Sierra
4A has been awesome for me so far. Have not needed lockers so far, but better to have it and not need it than to need it and not have it. Same as my recovery strap...
zjc26138
Zach
Steubenville, Ohio
2021 Bronco Sport BB
I feel this. haha. I drove a 2012/2015 Mustang for 9 or so winters in eastern ohio. I think I'll be fine with the Bronco.
Thed
Ben
Raleigh, NC
Please don't use lockers on roadways...
Gnomad
Harbor Springs
Land Rover LR3 HSE
I just brought my Base 7Mt home through a blizzard in NoMi and drove through 14"of fresh snow in4H, no trouble at all. Factory Duelers work just fine but still have some Dynapros on order.
redvettx2
Tom
Scottsdale, AZ
05 Maserati Coupe GT,16 Jag F-Type S,65 Cobra 427
Tires are everything. I had a Rubicon with 35 but more desert rock crawling tires. Horrible on hard packed road. Stock little Toyota on skinny tires just drove on past. I ended up locking all 4 and sticking 2 tires in the ditch for traction. That was an eye opener as I have pull snowmobile trailers all over the west and up mountains so I know how to drive in the snow. AT Tires were worthless. I had other AT tires Goodyear KO's rocked in the snow. Best if sipped. Softer rubber had way better grip.
