C135 ABS Connector Diagram
RSNovi
MI
2022 Bronco OBX
Hi,
Does anyone have access to a pinout of connector C135 which is the connector to the ABS module?
I have a DTC that says right front wheel sensor is short to ground or open circuit. I replaced the sensor and same error. I think I have a broken wire. I did a continuity test from the sensor connector back to the ABS connector. Trial and error I was able to find continuity for the two left front sensor wires and only one for the right front sensor. The green/white wire seems broken, but I am not sure which pin it is. Than you.
RSNovi
MI
2022 Bronco OBX
@Ducati1098
Sorry to bother you again. Would you happen to know the location of connector C1137 on the vehicle? I found some additional diagrams, and it appears to be an intermediate connector where the right front wheel speed sensor passes through. I could probe there to determine if the break is before or after that point.
It's been cold and rainy, so I haven't been able to work on it since I initially disassembled it. Hoping to have a plan for this weekend to get back to it. Thanks.
Ducati1098
@Ducati1098
Ford Bronco C135 ABS Connector Diagram 1775495715170-ry
Ford Bronco C135 ABS Connector Diagram 1775495755526-o0
RSNovi
MI
2022 Bronco OBX
Thank you, again!
RSNovi
MI
2022 Bronco OBX
RSNovi
MI
2022 Bronco OBX
I was able to get this working. Turns out I had received a left wheel speed sensor and I was working on the right side.
With the correct sensor in, everything started working. My wire repair was sufficient.
