Bronco Wheel Spacers
broncorocco
SF
PWillette
Parrie
Maine
A 25mm (1") will put you at basically same offset as Sasquatch...you'll have a bit of poke beyond the non-sas flares.
mhorvath1218
2022 Bronco Badlands
I bought Mishimoto’s “Borne off road” 30mm spacers for my non-sas badlands. With stock wheels, it equates to roughly the same offset as Sas wheels. I also installed 315/70r17 KO2’s and have non-sas flares. I think the poke looks perfect and have 0 rub. Nice quality spacers too.
Ford Bronco Bronco Wheel Spacers IMG_9567
broncorocco
SF
25mm front and rear? I wouldn't mind a little poke.
broncorocco
SF
That actually looks perfect! I might go with 30mm all around then. They have bigger spacers but I don't want the wheels poking out too much.
PWillette
Parrie
Maine
Lak34ers
Troy
Seattle
Hello everyone,
I'm new to the forum. I'm looking to improve the stance of my bronco with spacers. I came across these lightweight wheel spacers that seem pretty good quality.
https://wheelspacerstore.com/products/lightweight-wheel-spacers-ford-bronco-2021
What size do you recommend to get? Looking for a more aggressive stance. Thanks!
I know I will get roasted for this but just my opinion. Buy the wheels with the offset you want and skip the spacers. I just put on nice hub centric 1.5 on my F150 and it just didn't ride the same and felt off...probably nobody would notice but I could after driving it for 8 years (2015). Took them off and back to driving great again.
So decided on my Bronco to go with RTR 0 offset wheels and still drives the exact same with the just the right poke. RTR is much lighter and worked for me without having to do spacers. Understand if you want to keep the heavy OEM wheels but my experience is that you can tell if there are spacers and a lot of places won't touch them even if they are the best like BORA or Mishimoto etc.
Just my opinion get the wheels you want with the offset you want.
broncorocco
SF
I've had spacers on all of my cars before. Never had an issue. This is the first vehicle I own that's not a sports car so I'm not sure if spacers would be different on these. The goal would be aftermarket wheels eventually but meanwhile spacers are a cheap option to improve the stance.
Gluestick
Josh
Nashville
instagram.com
I’ve got BORA 1.25” on my badlands Sasquatch. Drives great and looks great with just a hint of poke. I wasn’t ready to change wheels/tires yet and quite like the bronco Sasquatch wheels honestly.
MRBOHN23
Matthew
Flanders, New Jersey
ordered a Bronco with badlands,sasquatch, lux
I have a Badlands Sasquatch with BroncBuster 1.5” spacers. It looks just right on a Sasquatch model in my opinion.
Ford Bronco Bronco Wheel Spacers IMG_1438
Ford Bronco Bronco Wheel Spacers IMG_1439
broncorocco
SF
The Sasquatch looks great! 1.5 inch should be around 38mm I believe.
Jfman
jean
Canada
Accord
(unlike cars) When the tires are this big, any imperfection at the hub is felt in an accentuated manner at the edge of the tire. Make sure to buy quality spacers and youll be fine.
Cbiggs
Cory
West Chester PA, OCNJ
85 CJ, 94 YJ, 04 JK, 17 Taco
I just put Borne 1.4” spacers on the factory OEM non-sas rims w/original KO2’s (44k miles w/some tread left). 315/70R17’s next, I believe.
Ford Bronco Bronco Wheel Spacers IMG_6338
Ford Bronco Bronco Wheel Spacers IMG_2121
Ford Bronco Bronco Wheel Spacers IMG_6340
Ford Bronco Bronco Wheel Spacers IMG_6334
Ford Bronco Bronco Wheel Spacers IMG_6676
1st 75th ranger
jeffrey
nj
nitto now makes 37x11.5x17 d rated and fairly light for a a t tire
that fit on sas wheels with 1.25' bora i hear no rubbing lol and no lifting needed
what say you ...worth a try
