swamp2
I've posted parts of this multiple times and it seems to be valuable and warrants its own thread. I'll probably edit the OP to keep up with comments/changes/corrections. Lets keep this to functional/performance and cosmetic, things like "different wiring harnesses" don't belong IMHO.
  • Drive train
    • 3.0 engine with more power and torque (418 hp/ 440 ftlb)
    • 37" BFG K02 tires
    • Larger/stronger F&R axles (Dana 44/50)*
    • Larger/stronger inner and outer tie rods (? might be same as HOSS 3.0 rigs)
    • Larger/stronger CVs and steering knuckles*
    • Beefed up transfer case clutches
    • Anti-lag turbo system (in Baja Mode)
    • Larger/stronger F&R driveshafts
    • Larger brakes (calipers and rotors)
    • True dual exhaust system
    • Larger lug bolts (14mm vs 12mm)
  • Frame/Body/Suspension
    • Internally reinforced frame (50% stiffer)
    • Rear carbon fiber cross brace
    • Larger/stronger suspension arms
    • Fox 3.1 Live-Valve internal-bypass shocks
    • More suspension travel F&R (13"/14")
    • Significantly wider track (+8.6")
    • Improved approach, departure and break over angles (47.2°, 30.8°, 40.5°)
    • Increased tire clearance
    • Disconnecting front sway bar**
    • More robust and more coverage for underbody skid plates
    • Increased water fording depth (37")
    • Stronger and reinforced hitch adapter
  • Interior
    • Fully digital instrument cluster**
    • Larger center screen**
    • Magnesium paddle shifters
    • Substantially better seats
  • Other
    • Transmission cooler
    • Larger/stronger HOSS 4.0 steering rack (? might be same as HOSS 3.0 today)
    • Greater towing capacity (4500 lb)
    • Larger radiator fan
    • Adjustable exhaust modes (Quiet, Normal, Sport, Baja)
    • Adjustable steering (Normal, Sport, Comfort, Off-Road)
    • Hood struts
    • Stronger rear tire carrier
    • Fog and driving lights in front bumper pockets
    • Amber grill marker lights ("Raptor Lights")
    • Amber front and red rear "width warning" lights in the side mirrors
  • Cosmetic
    • Different fenders with larger fender flares
    • Different hood cowl with functional cooling
    • Signature headlights with amber DRLs
    • FORD logo grill
    • Unique Raptor taillights
*There is some debate as to whether the front axles and CVs are truly upgraded vs. all non Raptor trims
** Are present on some non-Raptor years/trims/options packages
RK Racing
Robert
Hawthorne, Ca.
23 jeep gladiator
Thank you very very, very much for posting this. I have a raptor on order right now, and I was really trying to find the exact differences between a raptor and others. Thank you again!
Bschurr
NY
Cosmetic:
  • And not a single “Bronco” mention on the exterior…
CarGuy
New Jersey
2023 Ford Bronco
You forgot to mention the cost over a non-Braptor - measured in $10s of thousands!
RK Racing
Robert
Hawthorne, Ca.
23 jeep gladiator
I added it up and I got “”approximately a $17,000 “”difference. Well worth it if you have the money.
Y2KFirehawk
PA
2022 Bronco Wildtrak
You forgot to mention it only comes in the absolutely terrible four-door configuration (sarcasm, I like the 2-doors but will never understand the moar door hate)
RK Racing
Robert
Hawthorne, Ca.
23 jeep gladiator
Come on now……. You know the attitude out there…….. “”” 2 door is a true off roader”””” “””4 door is a soccer mom’s car””””…….. We have both.
Dral97
Ford Bronco, Wrangler YJ, LJ, and 392, BMW 4 series
Thanks for this. Care to go into why the seats are substantially better? No sarcasm, I just really would like to know. I wish the Raptor had a bit more differences in the interior.
These have grown on me over time. I did not like the way they looked when I first saw them. The body color matched fenders helped the most in getting me to start liking them. If within a year or two there is no bronco hybrid and if the Scout fails to wow me (starting to go in that direction), then I'm probably going for a Raptor.
swamp2
swamp2
Debbie Downer...
And should that be accompanied by a clarification that you get massively more in upgrades than you would add by trying to mod to the same level with aftermarket parts? That wouldn't even include the labor expenses.
swamp2
swamp2
Best of luck on your decision. You should really drive a Raptor off road before deciding 😉.
Seat differences:
  • Larger/improved side bolsters (and overall shape change)
  • Leather and imitation suede option available - adds luxury and grip
  • Cosmetic edge stitching (also on Stroppe)
swamp2
swamp2
You're welcome. It's kind of late in the product cycle to post it, but it really didn't exist anywhere else, even in a single Ford document.
RK Racing
Robert
Hawthorne, Ca.
23 jeep gladiator
Before we ordered our 2026 Ford raptor about a month ago I googled, YouTube’d and everything else to try to learn what the differences were as close as i could to 100%. We did test drive a bad land with the Sasquatch package and also a brand new Raptor. Your list looks like it list’s 100% of the difference’s or damn close to it. You Da Man!!!!!!!
Did they ever do Recaros in the Braptor?
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
The Ford performance warn winch kit will bolt on, but the software does not allow for the crash sensor reprogramming.
