BRBN Offroad 2.8 Shocks
srob63
KY
2025 Bronco
Looks like a good set up. Might be worth a shot after the stock Bilsteins give up the ghost.
They've got a promotion on this site right now to get a discount on them, and a chance to win a bigger discount.
They publish a lot of data, which is encouraging, but I don't really know what I'm looking at with the charts to be honest.
Just looking at retail prices - they make a lot of hay about being equivalent to Fox, but somehow cost the same as, or more, than the Foxes they are showing they are equivalent to. SO not really sure why I would go with this new shock, from a new company, that may or may not be around in 3-5 years when I need support rebuilding my shocks... versus just going with Fox, a proven company that has been around for a long long time... when both options are pretty much same performance and same price.
telenerd
telenerd
Laramie
Subaru
I hear they also have a Bronco6g discount too. Yeah I agree we need more info on their shocks before dumping 5k on shocks. Seems like a great company. Nice to see more options available for Bronco!
BRBN_OFFROAD
Andrew
New Hampshire
2025 Bronco, 2020 F150, 2017 F350, 2024 F550
Hello again Brian!
The data is published and available to show transparency, and also provide insight for individuals who are tech savvy on the subject; we felt it made more sense to make it available for everyone vs stating it was for our internal eyes only when requested.
In my opinion there isn't a right or wrong suspension choice, its more about making the correct choice for your budget and personal goals of the vehicle.
In relation to the comparison article you noted, you are correct the prices are similar- but there are some key differences between the two side by side:
3-way damping (HSC,LSC,Rebound) adjustment vs 2-way (HSC,LSC)
Oversized 2.8" aluminum body (12% more volume) vs a standard 2.5" (which comes within 6% capacity of a 3.0).
2.5" Piston vs 2.2" +/-
Lifetime Warranty vs a 1 Year
Some people enjoy working with boutique brands and small companies, while others prefer the "big name stuff ", it just comes down to personal preference in my opinion, likely pros and cons to both.
PS- Not trying to hijack the OP thread, but wanted to at least chime in and share some details for those reading, since that is in part why we are part of the community here!
If anyone has any questions feel free to DM or give me a 📞.
Cheers,
Andrew
HighVelocity
Big Sky Country
Pinto
This is the major sticking point when spending big money on shocks from a company that seemed to just pop up out of nowhere.
We don't know who's lifetime is going to be the determining factor, yours or mine?
You appear to offer a great value, but if you're gone in 5 years when I need a rebuild, then it's not a great deal at all.
87-Z28
Andy
BMW
I appreciate the data transparency. I have been looking for relevant shock damping force vs piston velocity curves for a few years.
BRBN_OFFROAD
Andrew
New Hampshire
FYI you can have these serviced wherever you please, it does not have to be done by us.
We have a tough crew here BRBN so don’t get discouraged. 😂
🤣 all good!
BRBN_OFFROAD
Andrew
New Hampshire
No problem 👍
Hello again Brian!
Cheers,
Andrew
That helps differentiate a lot - thank you
Not to derail too much but I do need new UCAs soonish and starting research and BRBN are on the list right now
BRBN_OFFROAD
Andrew
New Hampshire
Howdy,
@BRBN_OFFROAD
Can we get your numbers posted to the shock sheet? You might have to contact the OP for access.
https://www.bronco6g.com/forum/thre...de-bronco-suspension-data-compilation.109821/
Sure thing!
I will DM the OP with all the specs :)
Here are some to hold us over:
(FYI I will be adding some 2-door rates next week to the data and website as well)
Spring Rates:
Bronco Standard Series Front: 560
Bronco Standard Series Rear: 224
Bronco HD Series Front: 672
Bronco HD Series Rear: 270
Coilover Length (37" friendly):
Front Extended Length: 23.4
Front Compressed Length: 17.9
Rear Extended Length: 26.0
Rear Compressed Length: 18.5
Body: Oversized 2.8" aluminum body (monotube)
Piston: 2.5" (linear valving)
Damping: 3-Way-HSC/LSC/Rebound
Warranty: Limited Lifetime (original purchaser)
Reservoir: Mounted via Bronco specific mounting brackets and hardware, paired w/ our CNC aluminum BRBN clamps (no hose clamps).
Cheers,
Andrew
telenerd
telenerd
Laramie
Subaru
@BRBN_OFFROAD
I just noticed the rebound is also adjustable on these shocks. I saw dobison also offers this but they are very difficult to adjust when on the Bronco or hear the clicks. Would you mind showing some pics or details on how easy they are adjust when on the vehicle? The front looks like it’s easy to get to. Not sure on the rear.
That would be nice feature. Most shocks don’t have this!
