RIDE Shocks, designed by AccuTune Offroad
AccuTune Offroad
AccuTune Offroad
2021 Sasquatch 4 Door, Jeep JLUR, Tacoma
@Jms1 @BAUS67 Sounds like shock length question was answered. Thanks @popo_patty
Ride Shocks - Front
Compressed length: 18.71"
Extended lengths: 24.30"
Travel: 5.59"
King Shocks - Front
Compressed length: 18.50"
Extended length: 24.60"
Travel: 6.10"
(with our recommended CV saver, we reduce extended length by .30")
Fox Shocks - Front
Compressed length: 18.79"
Extended lengths: 24.26"
Travel: 5.47"
AccuTune Offroad
AccuTune Offroad
I am impressed that someone finally posted actual spring rates. The heavy spring rates are almost identical to what I ended up running on my FJ.
Our rear springs are custom triple-rate springs. Both of those springs can be used on King Shocks as an upgrade if you have added weight.
BAUS67
redneck
Central PA
Ride Shocks - Front
Travel: 5.59"
King Shocks - Front
Travel: 6.10"
Fox Shocks - Front
Travel: 5.47"
Yes it was and thank you for responding. Numbers look good, which I did not doubt just wanted to see the facts. I am looking forward to the @popo_patty video.
AccuTune Offroad
AccuTune Offroad
No worries, happy so share!
We do have a very lengthy and detailed we are working on that compares Fox/King/Ride. I think this will really help explain how much different our shocks are.
BAUS67
redneck
Central PA
Fan-freaking-tastic !!!!!!!! That would be awesome.
turbo_jimbo
Jimbo
Las Vegas
2dr wildtrak, zl1 1le, navigator, other stuff
Are the projected lift heights over Sasquatch?
SierraBronco
If you're in the market for high quality aftermarket shocks that provide the best ride quality possible, RIDE Shocks is it! We've been working on this shock project for 4+ years now, and we're thrilled to finally offer our very own shock brand, Ride Shocks.
-Ride Shocks are 100% designed and assembled here in San Diego, California.
-Ride Shocks are pre-tuned based on your Bronco's front & rear weight range.
-We have (2) front & rear coilover options that are outfitted with different spring rates & valving.
-Each shock option will come with weight range specific valving with the main piston and the adjusters.
-2021+ Bronco specific Shock Fitment Guide
-Every shock is a 2.5" aluminum body design that is equipped with our patent pending Dual Piston Adjusters. The adjusters offer 12 clicks of high and low speed compression adjustments.
-Our shocks flow a ton of oil with massive -10 shock fittings & hoses and are specifically designed to work with our linear piston.
-These shocks have it all and we've been testing and tuning like crazy to make them ride amazing both on and off-road.
-Ride Shocks carry a 3 year / 50k mile warranty and 30 day money back vow
-Ride Shocks will be available on www.rideshocks.com or sold in packages on www.accutuneoffroad.com
Take a look and let us know what you think! Please post up any questions you may have or send a private message. Thanks!
Also looking forward to seeing @popo_patty video from Overland Expo soon!
I tried calling you guys to get some details and place an order for our build, but got left in the nothingness of forever hold 😢
It was shortly after the youtube video came out so the lines were probably flooded. 🤷🏼‍♂️
Silver-Bolt
Bill
Eureka, MT
Could they be used on the Fox HOSS 3.0 Wildtrack shocks?
AccuTune Offroad
AccuTune Offroad
Sorry about that, happy to help get you in contact with our sales team if you havn't gotten through yet. Half our sales staff was out at Overland Expo West. Send over a PM and I can help out with anything you need.
AccuTune Offroad
AccuTune Offroad
Negative. Those will need an pigtail style coil spring vs a flat ground spring.
AccuTune Offroad
AccuTune Offroad
SierraBronco
**sad bronco noises cease**
Pressurized
Rod
Gilbert, AZ
Gen 6 Bronco - Jeep JKU - Wrangler LJ (sold)
With the 0-4.5" rating you have on them, is the shock too far out of it's designed operating range when ride height is set at 0"? Not much up travel and lots of droop...
Personally, I would like to do fronts at about 1.5" lift and rears at about 3/4" of lift.
Sdjohnson
Stephen
Ford F150
@AccuTune Offroad, do you know of any springs that will work with the Hoss 3.0 Wildtrack shocks to help with extra weight?
I'm aware of some taller springs by Eibach, but they're actually slightly softer. Also, I heard the Dobinsons might fit. Curious if y'all are aware of anything else/new?
Thanks
