Brandmotion fullvue mirror
Billnchristy
William
Georgia
2022 Bmw m440i gc,2022 BD 2dr, 1966 mustang
Maybe it's just me, but it seems a more elegant solution would be for the mirror to utilize the existing Bronco cameras. If this mirror could could tap into those video feeds, it would be a simpler solution.
But the stock camera looks like a 90s webcam.
Bee Bop
Bee Bop
Shane
Temple GA
21 Bronco Badlands, 02 Mustang GT Vert, 91 S10
I finished my install last night but now I'm getting a 'park aid fault' warning on startup. Has anybody else had this?
I did not. I recommend checking your fuses and make sure they are seated properly. This may be dumb question, but you did put the old fuses in the lower slot on the taps?
22Badskwatch
Sacramento, CA
2022 Badlands Sasquatch
was considering one of these, but after seeing all the problems y'all are having, I think I'll steer clear, LOL
5PC24
Pacific NW
2023 Bronco
Anyone have a ballpark cost of buying one including installation at a good shop?
buck_6G
Austin, TX
Toyota Tacoma TRD Pro
OP, is there any noticeable video lag?
WhiteRock
Canada
4dr Bronco
here you go. I haven’t had any issues with the mirror losing the date settings. As you can see the fuses are facing each other the top one is the constant and the bottom is the switched
Thank you sir!
Warnock
Randy
New Jersey
Hyundai Genesis
Does this void any warranty?
Peter_benton
Peter
Pt Judith, RI
Bronco Raptor, Escalade V, SL63
I have this and it’s great, color is a little purplish? I have the factory gm version in my Escalade and it’s crystal clear. Hopefully better quality ones come out in future
ntavera
Puerto Rico
I just install it and also is resetting the date to 2020 every time its turn on. Also it is defaulting to the dash camera every time the vehicle is turn on, is this normal? Since this is a rear view mirror I'm expecting to default to the rear view camera.
Aman
Aman
Northern NJ
Make certain you are using both fuse taps and have them in the correct locations. One is an always on 12v that keeps settings and allows for recording when the mirror detects a disturbance.
Peter_benton
Peter
Pt Judith, RI
Mine doesn’t reset to date..
But the picture quality is marred by the mirror image being combined with the camera.
Have the gm factory one in another car and it’s spectacular!
Aman
Aman
Northern NJ
I have mine angled up towards the roof a bit. The image is still crisp and clear, but I don't have to deal with the mirror reflection.
ntavera
Puerto Rico
I already check it and they are in the correct locations, also I checked the power with a multimeter and they have power.
What about the default camera, What are people getting when turning on the vehicle? Mine is defaulting to the front camera.
Peter_benton
Peter
Pt Judith, RI
Alas.. not really I have top and doors off till the cold and snow come!
Aman
Aman
Northern NJ
If you haven't yet, connect the multimeter to the always on 12v and place it somewhere you can see it from outside the Bronco. Close and lock the doors, wait 30 minutes. Then, without unlocking or opening the doors, check the meter to make certain that wire is still providing at least 12v.
Mine defaults to whichever camera I was last viewing. I'm guessing yours is defaulting to the front camera because it's not saving your settings.
