Borne Off-Road Wheel Spacers
Status
Not open for further replies.
Mannym5
Manny
Huntington, NY
2022 Ford Bronco BD, 2016 BMW M2, 2001 Honda S2000
Did you ever swap to 1.4in? I'm curious about what your experience was. I've got the same wheels.
Thanks
1.4 was out of stock at the time, so I ended up getting a set of 1.25 Bora branded spacers and they fit perfect. Very happy with them.
Ford Bronco Borne Off-Road Wheel Spacers IMG_7355
Ford Bronco Borne Off-Road Wheel Spacers IMG_7499
Ford Bronco Borne Off-Road Wheel Spacers IMG_8412
Ford Bronco Borne Off-Road Wheel Spacers IMG_8437
Ford Bronco Borne Off-Road Wheel Spacers IMG_8431
Ford Bronco Borne Off-Road Wheel Spacers IMG_8443
Simcoe-Bronco
Oro-Medonte
Hey Gang!
Nick here from Borne Off-Road! I just wanted to kick off this thread with some exciting news that we have a solid selection of wheel spacers available for the 6th Gen Broncos! Make sure that you head over to our Engineering Blog for some more insight on wheel spacers and our design:
FINDING SPACE – BORNE OFF-ROAD WHEEL SPACERS
Here's a quick look at the difference with our 2" (50mm) spacer installed on our Badlands:
Make sure that you also head over to our website to pick up a set today!
Borne Off-Road Wheel Spacers, fits 2021+ Ford Bronco 2.3L/2.7L
As always, don't hesitate to read out with any questions that you might have!
-Nick
Hey Guys!
I spent some time yesterday with our 2.3L base to create some visuals on our wheel spacers! We installed a set of our 1" and 2" spacers with the base steel wheels:
Don't hesitate to reach out with any questions that you might have!
-Nick
Hey Gang!
-Nick
Hi, new to the site.
Was hoping like others, you could help determine if a 2" spacer will fit my 2022 Bronco Wildtrak.
I'm running OEM tires and the bead-lock capable rims.
Let me know what info you need and I'll try to provide that info.
Thanks
Mishimoto
Mishimoto
Garnet Valley, PA
F-250
Thanks
Hey @Simcoe-Bronco - welcome to bronco6g! Fellow Wildtrack member @Boonie shared some awesome pictures of Borne Off-Road 2" wheel spacers installed on his Wildtrack back in Post #31 (click this hyperlink).
Hope this helps!
- John
Simcoe-Bronco
Oro-Medonte
Mishimoto
Mishimoto
Garnet Valley, PA
F-250
Wtb13000
Wyatt
New Jersey
2023 Bronco
Does anyone have experience fitting 37’s on their wildtrack without a lift after installing these spacers with stock Sasquatch wheels?
I believe stock sas wheels are +30offset so the 1.4” will move the wheel to 35.5mm or put the wheel at -5.5 offset. I believe the sweet spot for 37’s is right around 0 offset.
Curious if these spacers and 37s will work without a lift before purchasing.
NJNMDoc
Southwest
Bronco Wildtrak
Hi- I can't answer your question directly as I hadn't moved to 37s pre-lift, BUT I do have these exact spacers listed for sale right now in the Marketplace if you wanted to give it a shot without paying full retail!
https://www.bronco6g.com/forum/threads/borne-off-road-1-40”-wheel-spacers.81654/
Migo
Roy
Houston, TX
www.instagram.com
Hi! I just ordered a set of 1.2” spacers for my Method 703’s with 35mm offset. I am running 35X12.5 R17 Nitto Ridge Grapplers, and they are rubbing my Zone UCA’s on the driver side after alignment.
Will these spacers work with my aftermarket wheels, without any trimming or replacing the factory studs? Thanks!!
Hey Gang!
-Nick
BlueBronco
DFW
The back of the factory wheels have "pockets.". If the studs extend beyond the spacer they will fit in these pockets. I used to run 1" spacers on my wife's Bronco with factory wheels and they worked fine.
Mishimoto
Mishimoto
Garnet Valley, PA
F-250
Hey @Migo - It depends. You may need to shave down the studs a little, but that's only if the wheels do not have a pocket on the back side between the mounting holes (pictured below).
Hope this helps!
-Josh
Ford Bronco Borne Off-Road Wheel Spacers image001
Migo
Roy
Houston, TX
www.instagram.com
Hope this helps!
-Josh
Thank you! My Methods do have a shallow recessed area between the holes. They look different than the picture (and maybe not as deep) but I think they will work. Fingers crossed!
TacosTuesday
Carlsbad, CA
'23 Badlands 2dr 2.7L
installed these (1.4")on my stock badsquatch and all is good. I had the stickerfab front mudflaps and after install, the passenger side tire rubbed on the mudflap at full lock. i replaced them with the IAG mini flaps and now plenty of clearance.
Ford Bronco Borne Off-Road Wheel Spacers 1703184748687
Ford Bronco Borne Off-Road Wheel Spacers 1703184733556
stance after install:
Ford Bronco Borne Off-Road Wheel Spacers 1703184623317
Migo
Roy
Houston, TX
www.instagram.com
Installed the 1.2” spacers today and had zero issues with fitment on the Method 703’s. They look great, although I have a tinge of regret not going a touch wider. I suppose my CV joints will thank me!
mcama47
Timothy
Minnesota
2024 Ford Bronco Black Diamond Sasquatch
This is my concern. I do not know if I should go with the 1.4 or 2 inch? I have run 2 inch on other vehicles in the past so leaning towards that. I wish I could try one of each to see how they look before buying. Im torn on what size.
Status
