Borne Off-Road Wheel Spacers
Status
Not open for further replies.
Boonie
Ryan
MI
These are the 2” on a Wildtrak. Just fyi.
Ford Bronco Borne Off-Road Wheel Spacers 57C00DBB-D7FD-401B-86D3-60EE568E658C
Ford Bronco Borne Off-Road Wheel Spacers 9B51B84B-4CC5-4C70-9F64-022B3B2E7203
Ford Bronco Borne Off-Road Wheel Spacers 18FD4558-42B4-4A67-911B-69F2E7D64EBF
_TJG_
Todd
Louisiana
2021 Bronco First Edition (4 DR)
Great! Glad to hear they arrived even sooner than expected! Looking forward to seeing some installed pics!
-Nick
Do you have any 1.5” in stock? I was Deciding between these and Bora but if I can get a set of these sooner that’ll most likely help my decision lol
Mishimoto
Mishimoto
Garnet Valley, PA
F-250
Looking great!
Yessir! I just scoped out the inventory and we have the 1.4" in stock in both blue and black
-Nick
_TJG_
Todd
Louisiana
Looking great!
-Nick
Thank you! I ended up placing an order last night, figured I’d go for it 😂
_TJG_
Todd
Louisiana
Awesome! Can't wait to see them installed!
-Nick
They came in today! It’s a very nice looking product, can’t wait to get them on!
Ford Bronco Borne Off-Road Wheel Spacers F9E0605A-0E91-40E1-9473-DED5D4DBFC3F
Cbiggs
Cory
West Chester PA, OCNJ
85 CJ, 94 YJ, 04 JK, 17 Taco
Hey Gang!
Nick here from Borne Off-Road! I just wanted to kick off this thread with some exciting news that we have a solid selection of wheel spacers available for the 6th Gen Broncos! Make sure that you head over to our Engineering Blog for some more insight on wheel spacers and our design:
FINDING SPACE – BORNE OFF-ROAD WHEEL SPACERS
Here's a quick look at the difference with our 2" (50mm) spacer installed on our Badlands:
Make sure that you also head over to our website to pick up a set today!
Borne Off-Road Wheel Spacers, fits 2021+ Ford Bronco 2.3L/2.7L
As always, don't hesitate to read out with any questions that you might have!
-Nick
These are cool, Nick. Something to think about for me, but I’m really interested in caliper covers for the stock badlands wheels to match the badge color. Apologies if this is off subject, the spacers are something I’ve been considering if I end up putting 35’s on.
RangerDanger
Sean
El Sobrante, CA
2021 Ranger Tremor
Nick, any real difference between the Ranger specific spacers and the Bronco spacers?
mattymik
Houston, TX
2019 Honda Odyssey, 2023 WildTrak
Correct! We had our 1" spacers installed on both our 2.7L with alloy wheels along with our 2.3L base steel wheels without needing to trim the studs
-Nick
Is this also the case on OBX wheels? Thanks.
NORCALGXP
Sacramento, California
2017 Raptor
BORA Spacer made in the USA Sparks Nevada. One inch spacer had to trim the studs.
Ford Bronco Borne Off-Road Wheel Spacers 20220227_085001
Ford Bronco Borne Off-Road Wheel Spacers 20220227_092129
Mishimoto
Mishimoto
Garnet Valley, PA
F-250
Great question! The short answer is nope! The Bronco and Ranger use the same hubs so they will be a direct fit on both vehicles.
So, we didn't have access to a set of the OBX wheels at the time of our test fit, but it will likely be the same case. It looks like these wheels also have the same pockets on the rear of the hub, too, which will allow you to fit the wheel without having to trim the stock studs.
-Nick
mattymik
Houston, TX
-Nick
Thanks, Nick.
Mannym5
Manny
Huntington, NY
2022 Ford Bronco BD, 2016 BMW M2, 2001 Honda S2000
Lookin good.. How close were the 1in spacers from fitting without trimming studs? Do you think if you went for the 1.4in no stud trimming would have been needed? I ordered 1in ones for my Black Diamond non-sas 17in steelies. Hoping they fit with no trimming needed. @Mishimoto did you test on OEM Black Diamond 17's?
NORCALGXP
2017 Raptor
I trimmed off about 1/8th inch on the back, the fronts studs were shorter maybe trimmed 1/16th. You should be just fine with 1.25 spacer. Best off luck.
Harumph
Frank
1200XL
You should probably sell 0.75" spacers, which are optimal for 37x12.50 tires using stock sasquatch wheels. It is OK for the stock studs to protrude (enough clearance in sasquatch wheels), but the spacer nuts cannot.
How much poke are you seeing with this setup?
Status
