MUDLVR
Justin
Colorado Springs
2022 Badlands Sasquatch
So BOTH CV axle's blew out at the same time. I was high centered in the front on a boulder, so both wheels were at full droop. I put the rear locker on and tried to back out but the ground was so soft that I was just digging a hole. Then I put it in drive and put the front locker on, which just made the wheels spin. As I was wiggling the steering wheel, I all of a sudden heard the load POP and immediately thought it was my steering rack. Luckily it was just the CV axles, and luckily I had a spare set at home! Coming from the Toyota IFS world, owning an FJ Cruiser and a 4Runner I knew instinctively to always have a spare set of CV axles.
BTW....I was running the stock sasquatch Bilstein's with a 3" spacer lift and Camburg UCA's when this all occurred.
I was able to get pulled up the steep loose dirt hill on the trail (since I didn't have 4WD any longer) and then when we got flat again I just drove home without any issues.
And when I got home I was coincidentally comforted with the delivery of my Radflo kit! So I started replacing the CV's and installed the Radflo's all at once. I got the driver's side all put together last night and will spend this evening and tomorrow doing the rest.
Ford Bronco Blew BOTH CV Axles Out at the Same Time 289722344_10159925967064438_7310852683987326172_n
Ford Bronco Blew BOTH CV Axles Out at the Same Time 289950712_10159925966964438_7503568714401030127_n
Ford Bronco Blew BOTH CV Axles Out at the Same Time 290305771_10159925967124438_8980001971632094602_n
Ford Bronco Blew BOTH CV Axles Out at the Same Time 290201714_10159925967209438_427202230097191210_n
Ford Bronco Blew BOTH CV Axles Out at the Same Time 290702659_10159921668679438_5406566640383798204_n
Ford Bronco Blew BOTH CV Axles Out at the Same Time 290263751_10159921668629438_8645759473477123328_n
Ford Bronco Blew BOTH CV Axles Out at the Same Time 290218118_10225327761652627_1918459863665485079_n
Ford Bronco Blew BOTH CV Axles Out at the Same Time IMG_20220430_070821_899 (1)
Hedrock
Rome
4dr EG Black Diamond
Sucks about the CVs, I remember reading somewhere that they should have been slightly longer from the factory. Glad you made it out okay!
Opinion on the Radflos yet?
cracKen
Washington
23 Bronco Badlands 7MT
akturbo
Seattle Eastside
Sucks that happened! I see you have a 3" lift, what's your plan to prevent this from happening again?
I think this is the 2nd time I've heard of CVs blowing at full droop, I don't recall how much lift the other one had. Sounds like we should never engage the front locker when we're full droop.
Edit: before I installed the 1.5" spacer up front I got hung up, was full droop, sounded terrible if I turned at all while locked. And that was stock!
broadicustomworks
Hanging Rock, North Carolina
BlueBronco
DFW
FYI, another RadFlo user mounted his reservoirs similar to yours and was rubbing them on full lock. Not sure what wheel / tire combo he was running but something you may want to double check.
Edit. I am not sure his new mounting location is any better.
VoltageDrop
Fidalgo Island, WA
23, 69 Bronco
With that much lift I wonder if the balls are right at the edge of the bell at full droop. Maybe Broncbuster can whip up a CV bell brace? :p Only halfway joking... it might work if there's room to have something clamping the outer diameter.
IDyeti
SPAM
Boise, Idaho
21 Bronco BD
That's some good carnage, what trail were you running?
CP650
C.
SF Bay Area
Tacoma
broncoepic
Bronco Badlands Sasquatch
I have the King adjustable coil-overs and had the external reservoirs mounted behind the front bumper similar to the Radflo. I've since relocated them to the rear of the vehicle tucked in behind the wheel well liner, similar to how Fox does their installation. I had no clearance issues with 35's w/ 0mm offset wheels. However, ran into an issue when upgrading to 37s. There is also the added risk of damage by rocks/obstacles at approach.
Ford Bronco Blew BOTH CV Axles Out at the Same Time IMG_8211
Ford Bronco Blew BOTH CV Axles Out at the Same Time 123_1
noliveaxle
john
Riverside, Calif
2015 jku rubicon
F. Glad my wife took mine and is using it as a daily. Hopefully by the time she gets tired of the manual, they have real modifications to prevent this. MUDLVR, thanks for posting and good for you to be ready and expecting potential problems.
sniffHound
W
Mississippi
Ford Bronco
Is full droop when your rear supension is as high as it can go or the feeling we have since we’re not built yet?
The first part was a serious question.
akturbo
Seattle Eastside
Its when your front tires are hanging in the air, your suspension is fully extended.
lapazleo
2022 bronco badlands
