Best Rain Cover (2025 edition)?
Roofus
Swamp
M3/Bronco
Now that’s it’s been a few years of new products coming out, what’s the consensus on the best rain cover(s) for 4-doors?
Thanks!
JustWideman
Justin
justwideman.com
Bronco Big Bend '24
Broncover.
I don't understand not covering the front, that's where most of the paint is that needs protecting from sun and hail, etc. Are these just to hide your stuff?
Mikey1287
22 Bronco, 72 Mach, 03 Mach, 69 Mach, 08 Harley
"Best RAIN Cover"...
These are in case you are caught out in the rain or bad weather with your top off.
lethalchristy
Christy
Wellington, FL
www.lethalperformance.com
2021 First Edition, 2013 Mustang GT
This is to protect your interior, etc. from the elements when the top is off. Assumed that was what OP was asking about.
I daily my Bronco so I'd never cover it to protect it. It gets FL sun daily lol
Roofus
Roofus
Swamp
M3/Bronco
lethalchristy
Christy
Wellington, FL
Thanks! Do you know if it will work with the front and middle panels off but the rear roof section still on?
No the whole top has to be removed.
lethalchristy
Christy
Wellington, FL
However, I believe they are working on a half cover for those type of situations to come out this summer.
Roofus
Roofus
Swamp
M3/Bronco
I just emailed them to check. I park in a garage most of the year, so unfortunately while I’ve got space to store the front and middle panels, I’ve got no where to store the cargo roof section. Appreciate the rec!
box986
Paul
NNJ/NEPA
23 GX460 22 Sport BB, 03 Caddy EXT PU, 96 Lincoln MarkVIII, 92 Toyota PU 4x4
How long does it take to put on?
Mikey1287
The Broncover?
I've been using mine each morning at work for the past month or so because of the pollen in North Carolina. I can get it on in just a couple of minutes and my bronco is lifted on 37s.
box986
Paul
NNJ/NEPA
So it appears Broncover & Rain Gear make versions for the 2dr. Anybody do a side by side comparison? The Broncover is more than double the price.
Mjasi3
Chicago
Razorback
Bill
Dallas
Lincoln MKX
I ordered from Coversandall.com because they have the Bronco measurements but you can adjust to your build. I'm on portals with 38's. 3" poke on each side. So I knew a "Stock Bronco" cover wouldn't work. They confirm all figures prior to fabrication. This fits like a glove.
