- First Name
- Nels
- Joined
- Aug 14, 2020
- Threads
- 36
- Messages
- 2,060
- Reaction score
- 4,275
- Location
- Northern CO
- Vehicle(s)
- 2014 2D JK on 35’s
- Your Bronco Model
- Badlands
Honestly I wouldn’t worry about it too much. As long as your tires are still fresh and not showing signs of feathering (inconsistent wear) it will be ok. I’ve encountered many different “correct ways” over the years but untimely the pic I posted has been the most common version recommended by people I trust. This method has never given me a reason to change. Next time just tell them what you want, if needed just print out this image and tape it to the steering wheel as a reminder. Following the same pattern in the long run is the goal but you should be fine. However tire pressure and use also plays a huge part in how tires wear. I do recommend always rotating the spare in ever time, lots of shops will skip this unless you specifically ask.So I think I made a total rookie mistake today. Took my Bronco into Belle Tire today to get my tires rotated. Assumed that since they work at a tire store and I don't, they would know what they were doing, so being a girl, I didn't ask any questions. They did all 5 tires and when they were done the guy told me that he rotated them clockwise. Hours later it dawned on me that I don't think he cross-rotated them like the many diagrams I've seen posted in this forum, I think he just moved them all one spot to the right.
If you decide it’s something you want to do It’s not hard to do it yourself if you have the right tools or maybe a friend to help.
Good luck!
