Bent rear lower shock mount, need advice
Love Shop Auto Lo
Lo
Fremont, CA
2007 911S / 2021 4door Badlands w/ Sas
Problem: My passenger rear shock mount is bent outward
Cause: Slamming down on a rock
What I need advice on:
Is it safe to drive on if I hammer the lower shock mount straight?
-Does anyone make a weld-on lower shock mount reinforcement kit NOT shock skid?
Ford Bronco Bent rear lower shock mount, need advice 68836555469__769A31CC-433D-40E1-B1CB-8E46F1E41283
^Rear driver shock mount for reference. Pay close attention to the metal section above and below the big shock bolt
Ford Bronco Bent rear lower shock mount, need advice 68836552645__CD668D48-3E95-4A89-B6EB-396457081EEB
^Rear PASSENGER shock mount. Remember the last pic? Look how bent out towards the wheel the shock bolt is.
Ford Bronco Bent rear lower shock mount, need advice IMG_3568
A relatively small rock next to OEM 35's deflated down to 12psi.
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
Ouch that's not good. I believe there are replacement weld on parts for that. You could hammer it back TEMPORARILY and be fine but I wouldn't do that as a temporary fix.
BudgetBronco
Tim
Pittsburgh, PA
www.youtube.com
I have done this mount replacement on a 2003 Grand Cherokee. It takes a lot of grinding and some welding skills, but the end result is a much stronger mount than factory.
Also, I am not sure if a hammer is going to be enough to get that back in to position. More likely will need a hydraulic ram or heavy duty come-along.
vrtical
Doug AI
GSMNP, TN
Fords
yeah a hammer isnt gonna do shit, its cutoff and put a new one on time.
0ne
Nate
CO
Flex
Gosh dang I admire you bruisers out there beating the living piss out of these new Broncos…I’m such a wuss 😬
Ironiguana
Would a shock skid not help with this? If not, how helpful is the skid actually? I am debating whether or not I need one.
Cygnusx1
Missouri
Cayenne; Tiguan
He has a skid on there and, apparently, it did not help with whatever situation he put his Bronco in. Generally, the skids will work for regular wheeling.
Love Shop Auto Lo
Love Shop Auto Lo
Lo
Fremont, CA
@2020FordRaptor thank you for being the safety supervisor voice in my head. I needed that lol
@Bronco_joe I've been digging for this! Thank you so much. Gonna order and weld this up. I shall report back later.
@NJRoadkill I'm surprised there isn't a lot of weld-on reinforcement kits. In the Toyota world there's a ton of companies producing reinforcement kits for old ass Toyotas.
Thanks everyone for their second of time and advice
Here's some pics from the weekend where it all went down at the Soup Bowl at good ol' Rubicon :(
Hedrock
Rome
4dr EG Black Diamond
Sorry about the mount, I didn’t realize you were the one with the white wheels. Killer vibes. Did the rock sliders (RTR I think?) hold up okay?
ChompSticks
ChompSticks
Cumming, GA
'02 E55 wagon, '98 Suzuki X-90, '96 Town Car
I bent both of mine one side way worse than the other. You'll need to remove the shock to get access to bend the mount. Find a very large adjustable wrench because you'll need the leverage and the ability to fine tune where you want the bend. Apply a fair mount of heat (torch) so that you'll be able to bend it. Have an extra pry bar or anything for wedging to keep from bending the mount too far out. Use a bolt that is the slightly wider than the shock mount and wedge it in between to help you bend the mount if you pulled it out too far. Get some paint to spray the mounts after you are done because you'll probably gouge the mount a few times.
Ford Bronco Bent rear lower shock mount, need advice 1666786576145
Love Shop Auto Lo
Love Shop Auto Lo
Lo
Fremont, CA
akturbo
Seattle Eastside
